15x7 vs 15x6.5 any advantages
Old Mar 7, 2006 | 12:13 PM
xmb63's Avatar
Default 15x7 vs 15x6.5 any advantages
Hey, Im gonna buy rota slipstreams and run a 195/50/15 tire is there a advantage to step up to the 15x7 rather than the 15x6.5. The 15x7 is $50 more and weighs more, its not a significate weight difference. I was just wondering if there is a reason to step up to the 15x7.
Thanks in advance
Old Mar 7, 2006 | 01:17 PM
Voyage34's Avatar
Default Re: 15x7 vs 15x6.5 any advantages (xmb63)
Im sure someone can word this better, but here goes...
Some tires will fit better on a 15x7 because of their section width. Wider tires will need wider rims to acheive optimum performance. I recall reading that 205/50/15 Azenis actually have closer to a 217 width and so fit on 15x7 much better than 15x6.5
Old Mar 7, 2006 | 02:03 PM
old man neri's Avatar
most 195/50/15s have an approved rim width of 5.5-7" So if you get 7" rims it will have more of a "stretched" look. If you get 6.5" it will be right in the middle so it will probably be better fitting.
Old Mar 7, 2006 | 03:06 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 15x7 vs 15x6.5 any advantages (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">most 195/50/15s have an approved rim width of 5.5-7" So if you get 7" rims it will have more of a "stretched" look. If you get 6.5" it will be right in the middle so it will probably be better fitting.</TD></TR></TABLE>
90teg
15
Nov 3, 2005 07:25 AM
808State
Jan 30, 2005 12:48 AM
ITSUKA
Jan 9, 2005 11:10 PM
BIGGIDYBOB
Oct 8, 2003 11:53 PM
Understeer
Sep 7, 2003 03:43 PM
