civic d series header?
Old Mar 7, 2006 | 12:01 PM
venom363's Avatar
Default civic d series header?
I bought a header off a local board and the seller claimed it would fit my car. the bolt pattern looked the same but the bottom of the header stopped about 5 inches short of my exhaust
so I am looking for help on what car this header was meant for.
I drive a 95 eg si hb
the support arm at the bottom is welded onto the exhaust flange
ill try to get pics up soon any help will be appreciated
Old Mar 7, 2006 | 12:10 PM
the soL that could's Avatar
Default Re: civic d series header? (venom363)
88-00 d series headers should all bolt up. it might be after the collector (your vehicle catback) that might be modified. correct me if i am wrong.
Old Mar 7, 2006 | 12:15 PM
venom363's Avatar
Hope this helps
the other problem was the hanger did nor line up either
Old Mar 7, 2006 | 12:24 PM
venom363's Avatar
by this image the hanger and flange look to be in the right place
mine is too short
mabee its for prior to 88?
Old Mar 7, 2006 | 12:28 PM
LoL... that collector was welded on. that's the other reason why it will not bolt up accordingly.
Old Mar 7, 2006 | 01:30 PM
venom363's Avatar
so why would someone modify it? to fit what?
Old Mar 7, 2006 | 01:46 PM
Wazup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by venom363 &raquo;</TD></TR><TR><TD CLASS="quote">
Hope this helps
the other problem was the hanger did nor line up either</TD></TR></TABLE>
is that an OEM header?
Old Mar 7, 2006 | 04:20 PM
venom363's Avatar
no it is a generic (no-name) aftermarket one
Old Mar 7, 2006 | 04:48 PM
97spooncivic's Avatar
Default Re: (venom363)
just go to an exhaust shop and ask them to add however much you need on the collecter
D.O.C.-Race
Welding / Fabrication
50
Oct 11, 2011 05:40 PM
venom363
Mar 27, 2006 01:46 AM
idriveadelsol7
Dec 19, 2005 11:39 AM
mkinpwrat12g's
Jul 13, 2005 07:16 PM
TrentWar
Mar 8, 2004 07:01 AM
