trouble with back disk brake conversion
Old Mar 7, 2006 | 08:40 AM
importkidd's Avatar
Default trouble with back disk brake conversion
i have a 92 civic hb, i just done a back disk brake conversion from a 91 integra, now my e-brake is bouncing around and won't stay all the way down and when i pull it up it goes strait up and only one wheel locks...what can i do to fix that???
Old Mar 7, 2006 | 08:41 AM
pdiggitydogg's Avatar
are they new cables?
what chassis are they for originally?
Old Mar 7, 2006 | 08:44 AM
importkidd's Avatar
yes they are cables, and there from a da chassis.
Old Mar 7, 2006 | 09:08 AM
new cables require some stretching, that is why you have one grabbing and the other not
da cables are probably too long, even if you routed them correctly...you should have bought cables that best fit your chassis - si hatch
Old Mar 7, 2006 | 09:23 AM
importkidd's Avatar
so what i should do is just get some cables from an si hatch and keep the arms or replace it all??? also with the new arms on there it makes the wheels stick out about an 1/8 of an inch.
Old Mar 7, 2006 | 12:25 PM
you need to use your civic control arms
just replace the cables, not the entire thing...
Old Mar 7, 2006 | 03:20 PM
importkidd's Avatar
what should i do about my wheels sticking out now???
Old Mar 7, 2006 | 03:31 PM
use your civic lca's...like I said
(LCA's are the part that connects to the wheel, fron the subframe - the shock is attached to it)
socialistic
58
Nov 18, 2010 01:05 PM
dohc_zc_build
Mar 15, 2010 01:12 PM
d15civ
Oct 5, 2004 09:14 AM
DailyBlown
12
Sep 1, 2004 05:12 AM
MugenHonda
Jun 12, 2003 05:14 PM
