wire tucks....ef specific...main harness
well ive started on my wire tuck, still dont have the motor out yet to get it really clean, cause im swapping out the stock one here soon anyway
but what im looking for are suggestions on where to run the wires. right now i have the main harness, fuse box and all that inside the car,a nd the engine side going through where the heater was. what im going for is the "suspended in air" look with really only things visible are the obvious things that cant be moved so easily.
where is the best place to run the main harness. i want it more over to the driver side, under the intake manifold area so you cant even see it from just looking straight at the bay.
i have the headlight wirings pulled inside the car, and down the frame rails. the fuse box, and ecu side of the harness all pulled de-loomed and taped up mounted under the dash.
kreatekustomz
Welding / Fabrication
11
Aug 3, 2009 08:36 AM
