Swapping an si into my hf
Old Mar 30, 2002 | 11:13 PM
The Brown Kid's Avatar
Default Swapping an si into my hf
What do i got to do with the wiring harness to make it work w/the si????
Can i use zc ecu???
Can i use my hf distributor????
Shift linkage??
Old Mar 31, 2002 | 01:38 AM
balistic CRX's Avatar
Default Re: Swapping an si into my hf (Iron Flag)
if your gonna drop in a si motor into an hf, it should be pretty easy (plug in and play). you should use and si tranny though. everything should hook right up. i dont know if you can use a zc ecu with a si motor but most likely it will work. the hf wiring harness is pretty much the same as the si except the EGR wiring which u dont have to worry about it. just leave that wiring alone, dont need to plug it in to anything.
[Modified by balistic CRX, 2:41 AM 3/31/2002]
Old Mar 31, 2002 | 08:22 AM
JCushing's Avatar
i think the zc ecu will make it run a little rich but the fuel maps are better. i think everything else will bolt up though. you might want to look into your cat options before you swap as the hf cat is right past the header instead of below the car.
Old Mar 31, 2002 | 09:29 AM
allmotorEG-SI's Avatar
i've been considering doing the exact same thing to my HF. the car is just to damn slow even with mods. By the way how much did you pick up your si engine for?
Old Mar 31, 2002 | 10:08 AM
Malgerus's Avatar
I've got 2 si engines in my garage along with 1 tranny We've gone bigger an better...
Old Mar 31, 2002 | 10:20 AM
Default Re: Swapping an si into my hf (89_Y_49)
do like the hyndai in SCC. put an engine in front and back. attache an auto tranny and put it in reverse put the front in drve and do some massive burn outs.
Old Apr 1, 2002 | 12:18 AM
Default Re: Swapping an si into my hf (CAMAROCRUSHER)
$50
:mR. PotAtO heaD:
14
Dec 5, 2005 01:58 PM
adeline
19
Jul 24, 2005 02:27 AM
89POS
Jul 24, 2004 10:29 PM
aaronbb22
Mar 18, 2004 06:21 AM
91HATCH
23
Oct 15, 2002 05:03 PM
