does a clutch master cylinder from a dc fit and eg?
Old Mar 6, 2006 | 07:29 PM
Tealeg88's Avatar
Default does a clutch master cylinder from a dc fit and eg?
Does a clutch master cylinder from a 94 integra fit a 93 si hatch?
Old Mar 6, 2006 | 08:01 PM
Sliced Beard's Avatar
Default Re: does a clutch master cylinder from a dc fit and eg? (Tealeg88)
yes, as does one from a 92+ Prelude
Old Mar 6, 2006 | 11:14 PM
99hatch.'s Avatar
yes it will fit
Old Mar 6, 2006 | 11:32 PM
sohctodohc's Avatar
Default Re: does a clutch master cylinder from a dc fit and eg? (ebp97ek)
would these MC make a diff on pedal feel or anything???
Old Mar 7, 2006 | 02:22 PM
Default Re: does a clutch master cylinder from a dc fit and eg? (sohctodohc)
the prelude one will
the DC CMC is identical but the Lude CMC is larger and will reduce pedal resistance.
Old Mar 7, 2006 | 09:01 PM
sohctodohc's Avatar
Default Re: does a clutch master cylinder from a dc fit and eg? (DirtySol)
it would reduce pedal resistance??? i thought with it being bigger (?) it would be able to push more fluids??? but then again i can be dumb to
Old Mar 7, 2006 | 10:53 PM
shyboi4u's Avatar
Old Mar 8, 2006 | 02:24 PM
Default Re: does a clutch master cylinder from a dc fit and eg? (shyboi4u)
With the hydraulic cylinder being larger, it requires less movement and force to create the same amount of hydraulic flow.
Old Mar 8, 2006 | 03:18 PM
sohctodohc's Avatar
so the pedal trave and egagement would be les??
Old Mar 8, 2006 | 03:22 PM
x2gold's Avatar
the pedal would be easier to push (with the larger). Travel and engagement can be adjusted. Also , dot 3, vs dot 5 has a diff pedal feel as well esp, when warm.
Old Mar 8, 2006 | 03:36 PM
Default Re: (x2gold)
You cannot use DOT5 brake fluid in a Honda brake or clutch system without changing all of the seals and rubber lines to DOT5 compatable materials.
You CAN, however, run DOT5.1 brake fluid. It is hygroscopic like conventional fluids but has higher comporession and heat resistance. DOT5 is a silicone based fluid.
The difference between Hygroscopic fluids and Silicone fluids is the following.......
Hygroscopic, a brownish/clear fluid (aside from aftermarket fluids like redline and ATE Super Blue), will absorb water and reject air, when water gets into the system (happens over time or if the cap is left off in humid conditions) the fluid will lower its heat resistance capabilities and give less of a pedal feel and lower the boiling point. Can be dangerous. Air can be easily bled out of the system.
Silicone based fluids (DOT5), have a deep purple color, do not absorb water but instead absorb air. By the fluid absorbing air, it makes it about as compressable as a slice of bread. Silicone based systems require special seals that do not allow air to pass and require more frequent change intervals and special maintenence. Water is repelled by Silicone based fluids so the boiling point will not be lowered.
if you need any more information feel free to ask or just go to http://www.howstuffworks.com
Old Mar 8, 2006 | 04:45 PM
shyboi4u's Avatar
who has done a preluDe cmc in a civic or integra? what are your comments about it?
Old Mar 8, 2006 | 10:05 PM
EJ1_203's Avatar
yes i used a gsr clutch master cylinder in my 94 civic coupe when i did my auto-manuel swap!
Old Mar 9, 2006 | 07:35 AM
shyboi4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboi4u &raquo;</TD></TR><TR><TD CLASS="quote">who has done a preluDe cmc in a civic or integra? what are your comments about it?</TD></TR></TABLE>
mhewitt
Transmission & Drivetrain
Nov 30, 2010 02:55 PM
B18_CX_978
Apr 1, 2009 01:28 PM
vdawg559
Jan 20, 2008 07:02 AM
itsJDMyo
Oct 24, 2005 05:02 PM
vtecdc2
May 20, 2003 07:27 AM
