Help Honda techs, car won't crank..
Old Mar 6, 2006 | 05:40 PM
siblue_gzer's Avatar
Default Help Honda techs, car won't crank..
1994 Honda Accord EX
Automatic transmission
120k miles
ok for some odd reason my wifre's car just will not crank. It's been driving great with no problems...somehow it just won't crank. I tried
- Jumped the battery and it's not it.
- The battery terminals were clean..and i even double cleaned them with brush..still not it.
- I checked the fuses and all seems fine
- It has a half tank of gas
- Car is in P (Park)
- Sounds like fuel pump is working when i turn the key
What else can it be? Help me out. Can it be the starter?
Any help/info will be appreciated....thanks.
Old Mar 6, 2006 | 05:57 PM
HondaTom's Avatar
Default Re: Help Honda techs, car won't crank.. (siblue_gzer)
First thing I would check is the starter relay. If you can hear the relay click when you hit the key, than you knows its good. If thats good id hook a voltmeter to the terminal on the starter and hit the key, to see if you are getting voltage to the starter. If you are getting voltage and no cranking, than you know you need a starter.
Old Mar 6, 2006 | 06:14 PM
ok, thanks...i'll check it out
Old Mar 6, 2006 | 06:36 PM
Honda-bond's Avatar
Default Re: (siblue_gzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTom &raquo;</TD></TR><TR><TD CLASS="quote">First thing I would check is the starter relay. If you can hear the relay click when you hit the key, than you knows its good. If thats good id hook a voltmeter to the terminal on the starter and hit the key, to see if you are getting voltage to the starter. If you are getting voltage and no cranking, than you know you need a starter.</TD></TR></TABLE>
Sounds good.
This may not apply, but I've seen alarm systems completely disable a cars ability to start when they are tampered with. For example putting in a stereo can affect an alarm and disable the cars ignition.
Long shot, but I've disabled car alarms in situations like this and suddenly the car stars.
Old Mar 9, 2006 | 12:49 PM
ok, i checked the starter and it's dead. i'm hoping that's the problem..thanks guys
Beats Bang
Honda Civic (2001 - 2005)
29
Mar 26, 2019 10:13 AM
mikeWho128
May 21, 2018 11:29 AM
Matt S.
Jan 31, 2016 11:24 AM
brandejo
Sep 22, 2013 03:41 PM
lilman36
Mar 13, 2004 04:52 PM
