D16Y8
Old Mar 6, 2006 | 05:22 PM
M2nR's Avatar
Default D16Y8
couple questions: first off i got a 00' EK coupe with a Y8 in it... that motors' dunzo and i was a little tight on budget so i just decided to buy another Y8 and turbo it again...
Im almost done with the swap but my question is if its easier to drop in the motor with the wire harness on it already? or should i drop the motor in and then connect everything? whats easier?
also i was removing the starter cable that goes from the batt to the starter (the batt was disconnected but connected it again to roll up my windows and forgot to unhook it) and sparks came out! could that have hurt anything? will the starter still work? or whats up?
any help would be awesome! Thanks H-T
Old Mar 6, 2006 | 05:36 PM
True_honda's Avatar
Default Re: D16Y8 (M2nR22)
i think it would be smarter to hook up wires with the motor in the car. And the starter should work just fine as long as you didnt fry and wires.
Old Mar 6, 2006 | 06:15 PM
M2nR's Avatar
Default Re: D16Y8 (True_honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by True_honda &raquo;</TD></TR><TR><TD CLASS="quote">i think it would be smarter to hook up wires with the motor in the car. </TD></TR></TABLE>
yah i was kinda feeling that to0
anyone else?
thanks
Old Mar 6, 2006 | 06:24 PM
bluemax189's Avatar
definately easier with the motor in the car. just label everything. most plugs are one matching and dont hookup to anything else, a couple are tricky and fit in one or two different places.
Old Mar 7, 2006 | 04:29 PM
M2nR's Avatar
Default Re: D16Y8 (bluemax189)
sounds goo0d
anyone else have some advice?
Old Mar 7, 2006 | 04:42 PM
97spooncivic's Avatar
after the motor is in
Old Mar 8, 2006 | 10:51 PM
M2nR's Avatar
Default Re: D16Y8 (97spooncivic)
Dunn Deal
Thanks Every<FONT COLOR="red">onE</FONT>
mitsuman
12
Jan 11, 2008 08:34 PM
EFstyle
Jul 19, 2006 07:07 PM
95eghatch
Sep 29, 2004 11:31 AM
SOHC_Brian
Jun 7, 2004 04:29 AM
Del_Sol_s
26
Oct 16, 2003 06:20 PM
