Need help with CEL 14...
Old Mar 6, 2006 | 04:33 PM
crooked muffler's Avatar
Default Need help with CEL 14 and partial throttle stumble...
i have an 89 DX 4dr w/ d15b2 with mpfi swap, i did this swap a month ago...
I know cel 14 is EACV, and I have that stumble at partial throttle which is also associated with this code from what Ive read...
we thought the old EACV was dead, so we put a brand new one in (140$!)...still code, still partial throttle stumble, and doesnt do anything for warm up in cold...
my brother checked resistance(one thing at eacv plug, and one thing at ecu pin) he said it was a 1/4 volt is what he measured, so we asssume the signal is going through; so then why the code....
the only other codes I get sometimes is 20(electric load), but more often then not its jsut 14...could it be a vacuum leak? if so we cant find it, and why do we still have code 14; EACV seems not to be working at all...
any suggestions would be much appreciated
Modified by cheap4dr at 12:23 PM 3/7/2006
Old Mar 6, 2006 | 04:49 PM
cr-x-91's Avatar
what ecu are you running. i think only the 90-91 manni had that sensor.
Old Mar 6, 2006 | 05:55 PM
Default Re: (cr-x-91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-x-91 &raquo;</TD></TR><TR><TD CLASS="quote">what ecu are you running. i think only the 90-91 manni had that sensor.</TD></TR></TABLE>
I think its an 88 crx si ecu
and its a 91 si IM...
could this be why???
Old Mar 7, 2006 | 08:15 AM
Default Re: (cheap4dr)
any1?
Old Mar 7, 2006 | 10:45 AM
Default Re: Need help with CEL 14 and partial throttle stumble... (cheap4dr)
ttt
Old Mar 7, 2006 | 06:30 PM
i dont think its the ECU and I dont think its a vacuum leak (because when you cover the TB it'll stall)...
Old Mar 7, 2006 | 06:35 PM
RCautoworks's Avatar
Code 14 - Electronic Air Control Valve
Lets extra air into the intake manifold, to help control the idle under different loads.
Check the O-rings, for mountng condition.
Clean the inside of the Valve after removing, using any kind of solvent that will remove carbon build up. By spraying it inside the two holes ect...
Place the flat end of a screw driver on the EACV while the engine is running. Place the handle against your ear and listen. Should hear something in there jumping back and fourth at a rapid rate.
EACV Sensor Wires:
1 Blue/Black
1 Yellow/Black
Old Mar 7, 2006 | 07:43 PM
Jonknee's Avatar
This has nothing to do wtih this but, sonic youth rewls my lyf3!1
Old Mar 8, 2006 | 10:04 AM
Default Re: Need help with CEL 14 and partial throttle stumble... (efnewb91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efnewb91 &raquo;</TD></TR><TR><TD CLASS="quote">This has nothing to do wtih this but, sonic youth rewls my lyf3!1</TD></TR></TABLE>
thats cool, new album out soon...
any other suggestions welcome...
Old Mar 8, 2006 | 06:59 PM
FIXED!!!!!!!!!!!!!!!!!!!!!!!
I bought a complete conversion harness off of ebay, and it made the swap much easier of course, and the guy did a good job...but he mixed up the two blk/yel wires, thats why my EACV wasnt working....so we switched the wires around and it runs like a champ!!!
thanks for everyones help tho...
crxricer66
27
Apr 17, 2008 09:05 AM
jetblack
May 16, 2006 06:20 PM
trianglegreg
Jan 17, 2006 06:43 PM
c for sea
12
Oct 22, 2004 04:52 PM
Lei Siew Long
Apr 24, 2002 09:27 AM
