ss brake line question...
Old Mar 6, 2006 | 03:42 PM
EngineNoO9's Avatar
Default ss brake line question...
so I'm taking my old lines off to put some ss ones on.... and I think these are already SS... Reason being is the outer sheath on one of them is busted open and underneath is a nice and shiny steel braided line.... I guess I didn't think they were cause it has a black outer sheath but um... wow... so uh... do I leave these on or replace with some russel lines that i got cheap but the outer protective sheat is still in tact although slightly discolored...
Old Mar 6, 2006 | 03:45 PM
MSchu's Avatar
My Name is Nobody
Default Re: ss brake line question... (EngineNoO9)
that's quite a predicament you got yourself into there
Old Mar 6, 2006 | 03:46 PM
EngineNoO9's Avatar
Default Re: ss brake line question... (MSchu)
lol the bike was used and there was never any mention of ss lines. they looked stock so i figured I'd get some and slap them on. only concern with the ones on there is the outer sheath is busted in the one place. i can grab a pic here and show you. the others are in good condition just slightly discolored...
Old Mar 6, 2006 | 03:47 PM
marmaladedad's Avatar
Y'know what, I have no clue. AFAIK, all SS makers purposely put on clear plastic over their lines so you can see that they really are SS lines. Using this argument, I would venture that your lines are not SS lines.
Hope you are able to figure it out.
Old Mar 6, 2006 | 03:48 PM
EngineNoO9's Avatar
Default Re: (marmaladeboy)
lemme take a pic... brb...
Old Mar 6, 2006 | 04:06 PM
EngineNoO9's Avatar
Default Re: (EngineNoO9)
the new ones...
sorry for the overly shitty pics... my mom's camera blows and i was in a rush... it's definitely steel though...
Old Mar 6, 2006 | 04:12 PM
EngineNoO9's Avatar
im just gonna replace them cause the other lines don't have the busted outer protective sheath.... slightly discolored but eh... it's no show bike...
Old Mar 6, 2006 | 04:18 PM
Odiedogcx's Avatar
AIRBORNE
i'm gonna venture a guess and say you originally had ss brake lines
Old Mar 6, 2006 | 05:07 PM
EGlovr's Avatar
we should hold a public forum on how to take pics
Old Mar 6, 2006 | 05:09 PM
4-ageTOg63's Avatar
Default Re: (Odiedogcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx &raquo;</TD></TR><TR><TD CLASS="quote">i'm gonna venture a guess and say you originally had ss brake lines</TD></TR></TABLE>
I second that...from the first pic. they definately look like ss brake lines....I don't know whats going on in the other pics
Old Mar 6, 2006 | 05:14 PM
EngineNoO9's Avatar
like i said the pics suck cause the camera is a pos and i couldn't get it to focus on the right thing. plus i was in a rush. im positive they were ss but the new ones are on and bled already. though i destroyed a bolt so i gotta get a new one tomorrow
Old Mar 6, 2006 | 07:22 PM
EngineNoO9's Avatar
well got them on and bled all my lines. gosh bleeding even with a vacuum bleeder sucks. god all 4 lines on the bike done for the new season
Old Mar 6, 2006 | 07:55 PM
Four lines w00t!
Does the SS clutch line offer better feel?
Old Mar 6, 2006 | 07:57 PM
EngineNoO9's Avatar
oh i didn't get a new one of those. i just re-bled everything. i want a clutch and rear brake line a lil later... i imagine it should give a better feel though... my fluid from before was looking a lil ugly so put new stuff in
Old Mar 6, 2006 | 08:00 PM
What did you change four lines for then?
Oh n/m. I misread your post. I thought you changed all four lines.
Old Mar 6, 2006 | 08:01 PM
EngineNoO9's Avatar
nah. god I would've been so frustrated if I had. changing the 2 made a mess. and bleeding the others in addition is just a pain. summertime ill probably get new ones for the clutch and rear
Old Mar 6, 2006 | 08:07 PM
I don't really see the need for a rear line. I did it for my F3 and didn't notice a difference. I've left the rear line stock for the SuperHawk, and again, no difference. YMMV.
Old Mar 6, 2006 | 08:12 PM
EngineNoO9's Avatar
heh. yeah. i was gonna do it more for conformity then anything. i highly doubt much difference would be seen with a rear line. you have a stock clutch right?
Old Mar 6, 2006 | 08:17 PM
Yep.
Just out of curiousity, how much brake fluid did you go through to bleed the clutch and front brake and rear brake reservoirs? I've only done each one, one at a time.
Old Mar 6, 2006 | 08:18 PM
EngineNoO9's Avatar
i used a little over 1 12oz bottle. if i hadn't needed to completely redo the fronts i could've done 1 bottle. I'd get two and hopefully you don't need the second until sometime later....
Old Mar 6, 2006 | 08:20 PM
I see. Thanks. I figure I'll use up both just to be safe, and especially since brake fluid doesn't keep well once it's opened.
Old Mar 6, 2006 | 11:50 PM
ngng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">Yep.
Just out of curiousity, how much brake fluid did you go through to bleed the clutch and front brake and rear brake reservoirs? I've only done each one, one at a time.</TD></TR></TABLE>
i completely bled my duc's front/rear and clutch liens..didnt even use 1/2 of my bottle of motul
Old Mar 7, 2006 | 06:49 AM
Default Re: (ngng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngng &raquo;</TD></TR><TR><TD CLASS="quote">i completely bled my duc's front/rear and clutch liens..didnt even use 1/2 of my bottle of motul</TD></TR></TABLE>
Was it a ten gallon bottle? Good to know the Duc's are frugal somewhere.
Old Mar 7, 2006 | 08:56 AM
EngineNoO9's Avatar
well i used about 6 fl oz on the front alone just to be safe. went out today and they seem to be slightly better then the old ones... i think these lines are bigger then the others too...
da1lydr1ver
Dec 15, 2007 10:50 PM
bb4ninja
Apr 19, 2006 08:11 AM
lowgman
Jul 21, 2005 10:13 AM
djbarber2
Sep 25, 2004 01:55 PM
ActiveAero
Aug 3, 2004 07:31 AM
