Changing the rear motor mount.
Old Mar 6, 2006 | 03:38 PM
pinecone's Avatar
Default Changing the rear motor mount.
I need to change out the rear motor mount. Do I need to pull the motor or anything to do it? Or should I just take it to a shop and have them do it? It is causing major rocking issues and I would like to get it fixed soon.
Old Mar 6, 2006 | 04:51 PM
cr-x-91's Avatar
its a bitch man. i tried but ended up pulling the motor, i had to do my clutch anyways so i just pulled it myself.
Old Mar 6, 2006 | 05:48 PM
pinecone's Avatar
Default Re: (cr-x-91)
ick, I may just have someone do it. See how much it costs, because it is a pain in my butt. It affects the whole car since its so tiny.
Old Mar 14, 2006 | 05:54 PM
pinecone's Avatar
Default Re: (pinecone)
$125 and 2 hours of labor to pull the motor mount, hmmm. I do need to get it done.
Old Mar 14, 2006 | 06:13 PM
jdmcars.com's Avatar
Default Re: Changing the rear motor mount. (pinecone)
It's a pain, but can be done. I do it in about 20 minute max without pulling engine. (experience/tool selection pays).
Really simply if you have SOHC engine in still; little harder with B DOHCs.
Remove the rear transmission bracket first.
Go for the hardest bolt first, the rear mount bracket bolt. I normally get this with a weird set up of tools, but it works.
I put a short 14mm socket. Then a 6" extention, then a 12" extention. I first put the socket on the bolt head, then I put the extention down, at a certain angle, but I don't "lock" it onto the socket......then put the 12" on to get over the manifold. The twist. The extention is not fully into the socket, but it does brake it free. Then I remove the 12" and start to loosen it and get it all the way out....then remove the last two remaining bolts.
What out, before replacing it -if you are replacing it with a stock mount -cut a slot out of the mount so that you can put the bolt in, then slide the mount on, then tighten it down.
But -while you have it out -you can replace it with a billet upgrade (which we offer)
Old Mar 15, 2006 | 05:38 PM
Sanj's Avatar
Default Re: Changing the rear motor mount. (jdmcars.com)
Got a question for you. I have a 1990 Honda CRX si with a b16a motor, I hear a intermittent rattle and rotational squeel from my car. It occurs sometimes when it very cold and sometime occurs hot. Noise is driving me insane. I think your vast experience might give me some direction. I have had the car checked by three techs and could nt see or hear anything. Some say possible wheel bearing, driveshaft or differential. I placed the car in neutral when the noise occurs and no change, noise increases with speed and then goes away after a while. Also my rear engine mount is like almost touching the subframe. Is there any way this can be adjusted? Thanks for ur help. I can be reached at sanj@toyotaonfront.com
Thanks for you help.
Sanj
Old Mar 16, 2006 | 03:07 PM
pinecone's Avatar
Default Re: Changing the rear motor mount. (Sanj)
Which is the rear tranny bracket, the one the sway bar and stuff is attached to?
Also will a 89HF rear mount work with a 91 HF, I am thinking no at this moment in time because upon further inspection they look different.
Old Mar 18, 2006 | 02:29 PM
pinecone's Avatar
Bump.
Old Mar 23, 2006 | 10:56 AM
r.wright's Avatar
good stuff
Old Mar 23, 2006 | 12:30 PM
pinecone's Avatar
Default Re: (mrrlx)
"good stuff"
Hmm, thanks for the good info.
Old Mar 23, 2006 | 12:56 PM
r.wright's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone &raquo;</TD></TR><TR><TD CLASS="quote">"good stuff"
Hmm, thanks for the good info.</TD></TR></TABLE>
just subscribing cause i need to change mine as well. sometimes you can use polyurethane filler from kragen. i might do that cause i need a quick fix. try this link also:
https://honda-tech.com/zerothread?id=1568168
i have gotten estimates for labor as low as $100 to replace my front and rear mount.
Old Mar 25, 2006 | 02:04 PM
pinecone's Avatar
Default Re: (mrrlx)
thanks bro.
AdamsAutoAdvice
May 25, 2025 05:21 PM
Brandon H.
Feb 16, 2013 06:31 PM
airikkCRX
Jul 27, 2008 07:52 AM
AzntaggeR
Feb 14, 2004 07:31 PM
Kato7997
Mar 4, 2003 06:03 PM
