question about grips
Old Mar 6, 2006 | 11:51 AM
danteisme's Avatar
Loved
Community Favorite
Default question about grips
the original owner of my bike put the grip up too far on the handle bar so that if you crack the throttle it stays there. its just to close and rubs and catches. whats the easiest way to move this back down a bit. i tried a little heat, that didnt work yet. any thoughts?
Old Mar 6, 2006 | 12:28 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: question about grips (danteisme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danteisme &raquo;</TD></TR><TR><TD CLASS="quote">any thoughts?</TD></TR></TABLE>
Cut them off and put some new ones on.
Taking off grips that are glued on is the biggest pain in the *** ever.
Old Mar 6, 2006 | 01:40 PM
marmaladedad's Avatar
Sounds like you've got a custom throttle-lock for some long-distance cruising.
Try sticking a needle-point-attachment (the name escapes me at the moment) connected to an air compressor and blow air under the grips. It should shoot them right off.
Old Mar 6, 2006 | 02:53 PM
rdblckSV650S's Avatar
Default Re: (marmaladeboy)
if you want to keep the grips, just take a box cutter to the side that rubs and cut a little bit off all the way around.
My friend had the same problem on his RR (from a previous owner), so we just cut a little bit.
You have to do the same thing on bicycles all the time.
Old Mar 6, 2006 | 04:26 PM
danteisme's Avatar
Loved
Community Favorite
Default Re: (slvrblckf4i)
ah ok, so theres no real way to slide it back a fraction of an inch so its not sticking? he replaced the grips once before so i dunno if he glued them on or how he did it.
Old Mar 6, 2006 | 07:09 PM
Grumpy Old Man
Default Re: (danteisme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danteisme &raquo;</TD></TR><TR><TD CLASS="quote">ah ok, so theres no real way to slide it back a fraction of an inch so its not sticking? he replaced the grips once before so i dunno if he glued them on or how he did it.</TD></TR></TABLE>
Air hose like marmalade said should take them off as long as they aren't really glued on there good. If they are cutting them off is the quickest and easiest method I've found. Plus new grips are cheap as hell.
Old Mar 6, 2006 | 07:56 PM
Default Re: (RebornGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RebornGSR &raquo;</TD></TR><TR><TD CLASS="quote">Air hose like marmalade said should take them off as long as they aren't really glued on there good. If they are cutting them off is the quickest and easiest method I've found. Plus new grips are cheap as hell.</TD></TR></TABLE>
Cutting is fun, too.
w1ck3dR
Honda Motorcycles
34
Jul 31, 2007 05:31 AM
xtremecoupe
Suspension & Brakes
Oct 29, 2005 12:50 PM
redboost10
Jan 14, 2004 07:03 PM
Jon7
Honda Motorcycles
Jan 7, 2004 06:28 PM
RGoose18
Dec 30, 2003 07:53 PM
