Another Icebox Question
Old Dec 26, 2003 | 09:15 PM
RGoose18's Avatar
Default Another Icebox Question
I got my Icebox for christmas and I'm not too happy w/ the construction. The top of the box doesn't seal up 100% (it's slightly jiggly) and the air horn doesn't create a 100% seal w/ the tube it connects to. My question is, is this normal for an Icebox or did I get a defect? Pretty pissed so any input is appreciated.
Old Dec 26, 2003 | 09:28 PM
sgT's Avatar
sgT
Default Re: Another Icebox Question (RGoose18)
sounds normal
Old Dec 26, 2003 | 09:33 PM
R134's Avatar
It's normal. They told me it was not totally sealed to prevent water ingestion.
Old Dec 26, 2003 | 09:38 PM
GettaluvR's Avatar
New User
Default Re: Another Icebox Question (R134)
i have the same problem
was thinking if it wasnt 100% seal which means it will lose some air too is it ? so are we getting max performance out of it ?
Old Dec 26, 2003 | 09:42 PM
RGoose18's Avatar
Default Re: Another Icebox Question (GettaluvR)
Which part of the seal are you guys dissatisfied with? I think I 'm more concerned w/ the horn not fitting right. It's pretty shitty that you pay $170 for a piece of plastic that doesn't even piece together correctly!
Old Dec 26, 2003 | 10:03 PM
GettaluvR's Avatar
New User
the air tube hide behind the turn signal !! connect to the horn is not seal good !
Old Dec 26, 2003 | 11:57 PM
sjracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">Which part of the seal are you guys dissatisfied with? I think I 'm more concerned w/ the horn not fitting right. It's pretty shitty that you pay $170 for a piece of plastic that doesn't even piece together correctly!</TD></TR></TABLE>
If you think $170 is bad, the Ice Box i have for my RSX cost just about $300 and it has the same problem as the one you are describing. The cover is a PITA to put on and it doesn't seal up properly, but Comptech designed it like that as to minimize the chances of hydro-lock. At least it works.
Old Dec 27, 2003 | 11:48 AM
skafia's Avatar
25 Year Member
I really didn't have that problem with my icebox, everything sealed up pretty good.
Maybe it's your installation?
Old Dec 27, 2003 | 11:52 AM
1GreyTeg's Avatar
Default Re: Another Icebox Question (skafia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia &raquo;</TD></TR><TR><TD CLASS="quote">I really didn't have that problem with my icebox, everything sealed up pretty good.
Maybe it's your installation?</TD></TR></TABLE>
Gotta agree, Although it wasn't the same quality that I was expecting as compared to OEM fit and finish wise, Mine is pretty decent. Mine also was one of the first one's though and I haven't looked at the newer ones lately.
Old Dec 27, 2003 | 02:58 PM
sjracer's Avatar
I don't know about the ones for the DC2, but the ones for the RSX all, and i do mean ALL, have the cover/lid problem.
Old Dec 27, 2003 | 04:18 PM
iperez's Avatar
I agree on the cover seal not being 100% tight but everything else is OK in my IceBox. Yes its kind of giggly up on the intake arm to the t-body but it works just fine.
Old Dec 27, 2003 | 10:16 PM
Eva01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GettaluvR &raquo;</TD></TR><TR><TD CLASS="quote">the air tube hide behind the turn signal !! connect to the horn is not seal good !</TD></TR></TABLE>
I put some tape around there to seal that. Duck Tape rulz!
Old Dec 27, 2003 | 10:19 PM
RGoose18's Avatar
Default Re: Another Icebox Question (Eva01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eva01 &raquo;</TD></TR><TR><TD CLASS="quote">
I put some tape around there to seal that. Duck Tape rulz! </TD></TR></TABLE>
That'll be my route, unfortunately
Old Dec 28, 2003 | 06:12 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: Another Icebox Question (sjracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjracer &raquo;</TD></TR><TR><TD CLASS="quote">
The cover is a PITA to put on and it doesn't seal up properly.... </TD></TR></TABLE>
I don't think anyone has ever described in detail the right way to put that cover on and off. It will seal properly, but it takes some practice and I think that most of us drive around w/out it properly sealed for a while before we have that "Oh!" moment and realise how it's supposed to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">At least it works. </TD></TR></TABLE>
I've had mine for quite some time, and don't have any plans to change it. It dynos well, and looks stockish so it doesn't attract attention when the hood's up.
Old Dec 28, 2003 | 09:45 AM
sjracer's Avatar
Default Re: Another Icebox Question (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
I've had mine for quite some time, and don't have any plans to change it. It dynos well, and looks stockish so it doesn't attract attention when the hood's up.</TD></TR></TABLE>
George Knighton: I'm assuming you have an Ice Box on your EP3, is that true? A couple of us over at clubrsx are having a problem with our Ice Box on our Type S. The hydraulic line that goes into the clutch slave cylinder is rubbing up against the right side (passenger side) of the snokle, which has caused the hydraulic line to cause an indentation (almost eating away) into the snorkle. Also when the clutch is fully pressed in to the floor, the clutch lever will nudge the snorkle to the left roughly 1/8". Are you having any of these problems on your EP3? Comptech has been notified about these problems from us, and one of our members should be going down to Comptech real soon to show them the problem. They say they haven't been able to produce these problems on their in house Type S, yet quite a few members on clubrsx have the same problem.
As far as the lid goes, it doesn't bother me that much. I guess they designed it to fit that way. The plastic they used for the box is real flexible, so as long as i can get the lid over the box, then i'm not worried. A member mentioned that because the box is so flexible, that might be one of the problems that caused the hydraulic line rub in the first place. He stated that before you place the lid on top of the box, there's clearance between the two. Once you place the lid on top, because the box deforms so much, it causes the snorkle to rub against the hydraulic line. Well at least that's one of our theories.
Old Dec 29, 2003 | 02:47 PM
ur31337's Avatar
My icebox fits just fine, I did have a few issues with the stock intake arm though. I just bought the intake kit and solved my own problem.
The box was sort of awkward to take on and off, until I realized how it all went together though.
Old Dec 30, 2003 | 02:00 PM
RGoose18's Avatar
George, when you say "most don't know how to take the cover on and off", what's the big secret? I don't understand how there can be a right or wrong method, it just snaps on and off.
&lt;-----------Ryan, who wants to be let in on the big secret
Old Dec 30, 2003 | 05:37 PM
ITR-Spoon's Avatar
Same here, mine seem to be sealed just fine.
Old Dec 30, 2003 | 05:51 PM
Dropspeed's Avatar
Default Re: Another Icebox Question (PY-ITR-#977)
When I had a Icebox on my ITR I drilled 4 holes, 2 on the front and 2 on the back of the box, through the cover into the box. I then used 4 push/screw??? things from the rear trunk area that normaly holds the rear trunk plastic in place to secure the cover.
Number 26 in the link below
http://www.acuraparts247.com/s...ch=no
Mattj
Old Dec 30, 2003 | 06:39 PM
H-T Order of Merit
George Knighton: I'm assuming you have an Ice Box on your EP3, is that true? </TD></TR></TABLE>
I'm sorry, but my Icebox is actually on my ITR, not the EP. Sorry.
Good luck w/showing them that problem. It seems to me I've heard of it.
Old Dec 30, 2003 | 06:41 PM
H-T Order of Merit
LOL...
I must be a bigger idiot than I thought, then.
It took the bunch of us about three months before the lightbulb went off.
Old Dec 30, 2003 | 06:48 PM
MattD@Stoptech's Avatar
It took the bunch of us about three months before the lightbulb went off.</TD></TR></TABLE>
On or Off? The lightbulb I mean.
Old Dec 30, 2003 | 06:49 PM
jetydosa's Avatar
25 Year Member
Default Re: Another Icebox Question (Dropspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">When I had a Icebox on my ITR I drilled 4 holes, 2 on the front and 2 on the back of the box, through the cover into the box. I then used 4 push/screw??? things from the rear trunk area that normaly holds the rear trunk plastic in place to secure the cover.
LMAO, I bought Matts Icebox from him, and I lost one of the screw thingies, so I emailed Comptech asking if I could get some more. They were like WTF (this was the only Icebox I had ever really seen up close). I even went so far to taking pics and sending sent to them, I thought they were idiots b/c they couldnt figure out what I was talking about! They were like, it just snaps on. LOL. So I figured he must have drilled it. I like your solution better Matt.
To summarize, Basically the snap on cover fits poorly on mine too.
Modified by Jetydosa at 11:02 PM 12/30/2003
Old Dec 30, 2003 | 07:53 PM
RockstarJR's Avatar
GetawayInMoscow
Audio / Security / Video
Sep 11, 2007 06:33 PM
kekekekevin
17
Sep 9, 2006 06:48 AM
jako_X
Apr 14, 2004 06:18 AM
redboost10
Jan 14, 2004 07:03 PM
Rasta
Nov 12, 2003 05:32 AM
