HELP
Old Mar 6, 2006 | 08:10 AM
88crx's Avatar
Default HELP
NEED HELP. just got new skunk2 stage1 pro series cams and gears installed. car seems to run fine but i got 2 problems - 1. when i try to start the car it i need to hold the gas down a little bit to start it or it wont start. 2. when im driving and come to a light the rpm would jump around from like 250 to 1000 and then it would stall. can sum1 please help me to determine what the problem is.
Ak_ef9's Avatar
Default Re: HELP (88crx)
Checked the timing with a light?
Old Mar 6, 2006 | 08:16 AM
88crx's Avatar
Default Re: HELP (Ak_ef9)
wat should the correct timing be? my car is going into the shop tomorrow for a new clutch. i can have it checked then
Old Mar 6, 2006 | 08:19 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx &raquo;</TD></TR><TR><TD CLASS="quote">wat should the correct timing be? my car is going into the shop tomorrow for a new clutch. i can have it checked then</TD></TR></TABLE>
What motor are we talking about here? It sounds like you may have skipped a tooth on the cam gears or something,,Or maybe the cams just need to be tuned..By the way where did you get skunk2 pros from?
Old Mar 6, 2006 | 08:31 AM
88crx's Avatar
Default Re: HELP (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">What motor are we talking about here? It sounds like you may have skipped a tooth on the cam gears or something,,Or maybe the cams just need to be tuned..By the way where did you get skunk2 pros from?</TD></TR></TABLE>
the motor is a jdm b16a with obdo pr3 ecu. and i got the cams from sum1 here on h-t (they were shipped directly from skunk2). i believe the problem is that they need to be tuned properly but dont know for sure. every thing was bought new in box
Old Mar 6, 2006 | 08:34 AM
crxnj's Avatar
Its very hard to get pro series..
But yeah they do need to be tuned but make sure the timing is correct also..Stock timing is 16 degrees btdc..Between 14-18 is fine..
Old Mar 6, 2006 | 08:41 AM
88crx's Avatar
i will try to have my mechanic take a look at tomorrow the only problem is that he is only a mechanic and not a honda tuner so it would be kinda hard for him to properly tune. i am trying to find a good place in nj to get my car dyno tuned.
Old Mar 6, 2006 | 08:47 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx &raquo;</TD></TR><TR><TD CLASS="quote">i will try to have my mechanic take a look at tomorrow the only problem is that he is only a mechanic and not a honda tuner so it would be kinda hard for him to properly tune. i am trying to find a good place in nj to get my car dyno tuned.</TD></TR></TABLE>
Yeah well he should atleast be able to check the timing..And if its off a tooth,,He should be able to fix it..Its pretty basic stuff for a mechanic..
As far as tuning goes theres a guy in bergen,NJ..Named chris (xenocron),,This guy tunes like no other..He does street tunes though,,but email him about dyno tunes..Check out http://xenocron.com for info..Im trying to think of anyother guys that tune hondas..THeres also greg in woodbridge http://GBRtuning.com..Theres not really that many tuners or shops that arent theives in this state..Im sure theres other good guys though somewhere..
Old Mar 6, 2006 | 08:56 AM
88crx's Avatar
thanks a lot i have been looking for some one good but with not much luck at finding a good shop. i have been going to a guy who did my motor swap who has built some hondas but have lost faith in him after the last install since he did not properly tune and i ts also a pain in the *** to drive to him all the time since i live in freehold and he is all the way in north jersey. i think im gonna try that place in woodbridge thanks.
Infamous war
May 6, 2012 07:29 AM
Speed Infliction
Feb 7, 2007 10:13 PM
88crx
Mar 6, 2006 08:50 AM
1badda
Oct 5, 2005 11:57 AM
Wilky
32
Dec 2, 2004 08:04 AM
