Driveshaft problems??
Old Mar 5, 2006 | 11:22 PM
skeg8's Avatar
Default Driveshaft problems??
I bought my 95 Civic DX a few months ago and since I bought it I have noticed a slight bumping sound in the front left when driving.. It is particularly noticable at 40mph in 4th (around 2000rpm). The sound does get faster with speed...
So when I installed a new exhaust yesterday I took a look at the driveshafts and I noticed that there is a small gap between the driveshaft and the transmission (about 2-3mm) I can see the shiny metal of the driveshaft going into the transmission. The CV is not butted up against the transmission cleanly. The right side looks ok.
Could this cause the sound I am hearing? Do I need to fix this soon or is it nothing?
The CV's sound good (no clicking) and the boots all look great... The tie-rod ends and ball joints also look ok.
Any thoughts??
Old Mar 6, 2006 | 09:29 AM
skeg8's Avatar
Default Re: Driveshaft problems?? (skeg8)
Anyone??
Old Mar 6, 2006 | 09:34 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
If the inner CV joint is bad, it will cause what you are experiencing, I think...
Old Mar 6, 2006 | 10:11 AM
skeg8's Avatar
Default Re: Driveshaft problems?? (JDM_Ej)
I think you may be right.... the sound is not very loud and it does not go away in neutral (coasting). The driveshaft itself is a little brown (could be from the mega rain hawaii just got) but the boots are new. So it may just be an old messed up CV...
Anyone have any experience changing driveshafts without a lift? It seems like a killer job to do with jackstands...
How much should it cost to pay a mechanic to replace the driveshafts if I supply the new ones??
gotgohan
Jun 28, 2013 09:28 PM
JReal
Suspension & Brakes
Sep 25, 2009 02:29 PM
Partizan
Jan 7, 2009 04:05 PM
erck
Sep 5, 2006 02:18 PM
mr devious illusions
Oct 5, 2004 05:02 PM
