3 inch DP with 2.5 Exhaust = Restrictive???
Old Mar 5, 2006 | 11:09 PM
A.E Motoring's Avatar
Default 3 inch DP with 2.5 Exhaust = Restrictive???
well i will be boosting in like a couple weeks to a month, depending on how funds go.Thing is i have a 2.5 DP but thinking about getting a 3inch, but my exhaust piping and muffler is a 2.5, i was wondering is anyone running with that set up? is it pretty restrictive according to tuning? if so i was thinking about either getting a 3inch DP and sticking with the 2.5 Exhaust or just sticking with the 2.5 DP and getting a Y pipe added on, or just get the 3inch DP with the Y pipe, so when it comes time to race just open it up, im not really wanting to spend more money on a 3 inch custom exhaust, if i was going to spend money on exhaust i rather use the money on a new/bigger DP, but just wondering if a 3inch DP with a 2.5 exhaust with a 2.5 muffler is really that restrictive, 1/2 inch makes that much of a difference??. TIA
Old Mar 6, 2006 | 03:04 AM
Marlon88's Avatar
Default Re: 3 inch DP with 2.5 Exhaust = Restrictive??? (SPNFEDEH)
https://honda-tech.com/zero...age=1
You can find good info here
Old Mar 6, 2006 | 05:35 PM
Default Re: 3 inch DP with 2.5 Exhaust = Restrictive??? (Marlon88)
damn, i guess it does make a difference
Old Mar 6, 2006 | 07:20 PM
Honda-Hooligan's Avatar
well that says it all for me 3" custom exaust now i wonder how much diference would it be with 3" DP as well
Old Mar 6, 2006 | 07:23 PM
TurboTeG4's Avatar
Default Re: 3 inch DP with 2.5 Exhaust = Restrictive??? (Honda-Hooligan)
Thats only for that particular setup, you will see good gains but I doubt that much, just cross ur fingers.
Old Mar 7, 2006 | 10:03 AM
Default Re: 3 inch DP with 2.5 Exhaust = Restrictive??? (TurboTeG4)
so guessing just the extra half inch makes a difference
Old Mar 7, 2006 | 10:18 AM
Blackack26's Avatar
Look at it this way:
2.5" = 4.9 inches squared
3" = 7.075 inches squared
Old Mar 7, 2006 | 11:43 AM
Mugencrxsir1's Avatar
Default Re: 3 inch DP with 2.5 Exhaust = Restrictive??? (Blackack26)
If you can weld and fab, then you can make your own DP back 3"+ exhaust from companies like jegs/jcwhiteny,summit, for less than $200. And that's T304 stainless, you just have to do your homework and look around for best prices.
Old Mar 7, 2006 | 11:53 AM
Blackack26's Avatar
Default Re: 3 inch DP with 2.5 Exhaust = Restrictive??? (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">If you can weld and fab, then you can make your own DP back 3"+ exhaust from companies like jegs/jcwhiteny,summit, for less than $200. And that's T304 stainless, you just have to do your homework and look around for best prices.</TD></TR></TABLE>
Yeah, but you need to factor in muffler and resonator(s) costs.
Old Mar 7, 2006 | 02:49 PM
Hybrid_Coupe's Avatar
on myt first set up i was on a 60-1 with a 3" downpipe into 2.5" crush bent exhaust and a magnaflow muffler and i made 514hp...that was also on a skunk2 intake manifold..stock fuel rail.
Old Mar 7, 2006 | 04:48 PM
Default Re: (Hybrid_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid_Coupe &raquo;</TD></TR><TR><TD CLASS="quote">on myt first set up i was on a 60-1 with a 3" downpipe into 2.5" crush bent exhaust and a magnaflow muffler and i made 514hp...that was also on a skunk2 intake manifold..stock fuel rail. </TD></TR></TABLE>
niiice
Old Mar 7, 2006 | 06:08 PM
drumking15's Avatar
ill sum it up for ya reallll quick
hx35 on ls/vtec
15psi
ramhorn mani
w/ 3" open dp....hit full boost about 4200rpm
w/ 3" dp to stock exh...full boost at about 5k
it makes a difference....a big one...think the bigger the pressure differential the faster your turbo is gonna spool....and also help the motor exhale the fumes and suck in some new ones
Old Mar 7, 2006 | 07:13 PM
Default Re: (drumking15)
i think im just going to get a Y pipe added to the DP, just so i dont have to get a full custom 3 inch exhaust. good idea?
Old Mar 8, 2006 | 05:53 AM
drumking15's Avatar
Default Re: (SPNFEDEH)
yep...best idea possible...all the power you want when you need it..and the quietnes to keep the cops away when your not playin
AzntaggeR
Mar 12, 2005 09:49 AM
97Preludeguy
Dec 24, 2004 11:22 AM
Derek14
Mar 23, 2004 09:10 AM
01ITR#700
Mar 17, 2003 01:28 PM
DC2R714
Aug 4, 2002 04:31 PM
