new d15 project heheehe
Old Mar 30, 2002 | 06:37 PM
Mugen Dom's Avatar
Default new d15 project heheehe
ok heres the deal wut do u guys think of a carbed or mpfi not sure yet... but a d15 botom end with a shaved d16a6 head ported and polished. d16a1 pistons curtisy of my pops junkyard of course and all in a d15b2 in a 90 std that we have sitting at the yard identical to mine i drive... fully gutted no nothing.. im still not sure how im gona do the fuel system but its gonna be a 12 sec car track only 12:1.1 compression about
NA of course let me know wut u guys think its just a side project for me to mess around with till i get another job to fund my turbo b18 project....
phatty i need my d16a6 head back u slacker
Old Mar 30, 2002 | 06:46 PM
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Default Re: new d15 project heheehe (jdmB18hatch)
Good luck on that project, try to go carb that will be tight. Keep is updated on how its going down. And always remeber to have fun. lates
Old Mar 30, 2002 | 06:47 PM
Mugen Dom's Avatar
Default Re: new d15 project heheehe (Lil Cs Zc)
12s with some help u know the kind in a bottle but 13s NA will be fine for me
Old Mar 30, 2002 | 09:27 PM
marty's Avatar
no bottle. carbed high compression.. you have to run some sort of external fuel management system. but 12's no bottle with some right headwork and some pistons and a good tuner.
EDIT: whoa whoa I disappear for 10 days and post counts are back? wtf?
[Modified by MugenEF7, 1:27 AM 3/31/2002]
Old Mar 30, 2002 | 10:48 PM
Urban Business
Guest
Posts: n/a
Default Re: new d15 project heheehe (MugenEF7)
lol you and me are in the same boat.. trying to fund the b18c1 turbo project =P
Old Mar 30, 2002 | 11:03 PM
*Boostwerks*'s Avatar
I got a D15 project of my own.
Me and my freind are building it up for 15psi boost.
V8'ers-
"WTF? that's a 1.5 liter? how did you just put down 300hp????"
Earns more respect than a dinky B-16!!
Old Mar 30, 2002 | 11:12 PM
Yeah If I had the Knowlege of Honda's back when I "NEEDED" to do an engine swap I would have just done that also.
Old Mar 30, 2002 | 11:59 PM
CRX-RX's Avatar
Default Re: new d15 project heheehe (Bryson)
Hey, I've got one of those projects too, a VX VTEC head on a D15 block, with MPFI, and probably either a NOS kit, or GReddy turbo kit. Maybe both, well...... probably both
[Modified by CRX-RX, 2:59 AM 3/31/2002]
Old Mar 31, 2002 | 12:07 AM
Urban Business
Guest
Posts: n/a
Default Re: new d15 project heheehe (CRX-RX)
hmmmm vx vtec? if its vtec its mpfi to begin w/. you deffinatly need naws and that turbo
Old Mar 31, 2002 | 12:08 AM
CRX-RX's Avatar
Default Re: new d15 project heheehe (TorteX)
Sorry, I meant D16 Intake manifold.
Old Mar 31, 2002 | 12:14 AM
Urban Business
Guest
Posts: n/a
i dont follow... oh well
Old Mar 31, 2002 | 07:58 AM
Mugen Dom's Avatar
im not using vtec and im not using a turbo im goin NA with this like mugenef7 said before its all in the pistons and teh head the car is only gonna weigh like1500 lbs so 180 hp should be good for a low 13 high 12 all motor and a 50 shot to 100 shot could put it down to low 12s i dont want to go into teh 11s but once at a track i dont goto so i can get kicked out hehe but im one not to condone n2o ill keep ya posted
Old Mar 31, 2002 | 08:25 AM
Iceycrx's Avatar
Mine is almost like a project, every damn thing has broke on it, heard hf or zc pistons were good also.
Old Mar 31, 2002 | 08:29 AM
Mugen Dom's Avatar
Default Re: new d15 project heheehe (Iceycrx)
zc pistons are an option but i have a1 pistons the dohc d16 here in the 86-98 teg the teg has a huge combustion chamber witch makes it have a low compression 9.5:1 but with teh smaller combustion chamber of a d16 a6 head shaved of course it will make a compression of around 12.1:1
Old Mar 31, 2002 | 01:42 PM
Mista Bone's Avatar
D Tranny Guru
but you do know that the 1.5L psitons are 3mm taller than any of the 1.6L pistons. You compression ratio will really suck using any 1.6L piston in a 1.5L. The Teg/ZC (same thing BTW) pistons MIGHT get the compression ratio back near to stock specs.
Old Mar 31, 2002 | 06:04 PM
4gvtec's Avatar
just put the dam thing togather and run it! iwant to know what is does.hehe. anyway bone- man here knows these d-motors from what i see and read.
Old Mar 31, 2002 | 06:19 PM
Mugen Dom's Avatar
Default Re: new d15 project heheehe (4gvtec)
ill put it together im pretty sure that it will work the a1 head ccs are like 15 more than a a6 head and ill be shaving the head also... liam is using zc pistons in his d15 and hes getting good results from it...
Old Mar 31, 2002 | 08:29 PM
ExospeedAMcrx's Avatar
12's is easy with a built bottom end.
I was running my D16A6 4yrs ago up until this year. It has headwork, custom cam, and just bolt ons. The block is stock and the clutch was stock when it layed down 13.6 passes. After 3 yrs, nothing has been done to the block or the head. and still hitting consistent 13's. And all this time, it was adaily driven car that was getting 30 mpg.
I always wanted to build the bottom end but this year we finally are doing it but as a full racecar. Its gonna have a sick *** high compression motor on C16 gas.
14:1 compression!??! hell naw.. were going way higher than that. Thanks to support from ARIAS and Bisi Ezerioah(10sec D15 allmotor), we'll get this project out by end of summer.
We'll keep you updated on the website on the transformation of the car from street car to full race car.
Back to the topic, let me know if you need some special cam for the D16 head, either Vtec or the non-vtec. I have em avail for the D series fans out there.
Wil http://www.exospeed.com
crex22@exospeed.com
Old Mar 31, 2002 | 08:42 PM
Aphrodavid's Avatar
D15s OWN!!!
Old Apr 1, 2002 | 03:17 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: new d15 project heheehe (exospeedAMcrx)
Bisi's motor is NOT a 1.5L!!!!!!!!
third lobe
Aug 27, 2007 02:13 AM
CRseXy
19
Dec 6, 2004 02:35 AM
phatrick2332
Feb 11, 2004 05:28 AM
BAZ
Jul 22, 2003 07:51 AM
93B17A
Dec 17, 2001 04:34 PM
