Dash lights won't work : (
Old Mar 5, 2006 | 07:37 PM
crxY-49's Avatar
Default Dash lights won't work : (
I searched and searched
All lights worked fine. Then I installed a CD player which is working fine, however the dash/climate control lights won't work anymore. All the other lights still work (tail, parking, etc . . . ) Could the dimmer have just **** the bed while installing the new cd player? I've checked the fuses all seem ok.
I tried disconnecting my cd player and they still won't work.
Please help. This is annoying.
Old Mar 5, 2006 | 08:05 PM
Relic1's Avatar
there is a dimmer output wire at the radio for the stock radio to dim when you have on the lights. If that wire shorted to ground you poped the dimmer.
Old Mar 5, 2006 | 08:11 PM
crxY-49's Avatar
Default Re: (Relic1)
would it be possible just to bypass the dimmer?
Old Mar 5, 2006 | 08:37 PM
crxY-49's Avatar
Default Re: (crxY-49)
i don't care if i can't dim
Old Mar 5, 2006 | 08:52 PM
novvti's Avatar
my dimmer broke as well, so how can i jump it without using the dimmer?
Old Mar 5, 2006 | 10:51 PM
ZipTieGUy's Avatar
recheck your fuses. look for the one that says interior lights or guage cluster. one of them is popped. trust me
Old Mar 5, 2006 | 11:29 PM
JDM-EJ1's Avatar
Default Re: (ZipTieGuy)
I wouldn't know how to bypass the dimmer switch. I would recommend going to a junkyard and buying one from there. Can't be more than few bucks.
Old Mar 6, 2006 | 07:33 AM
crxY-49's Avatar
Could it still be a fuse if all other lights work? ( dome, parking etc . . .)
I'll go double check the fuses now.
Thanks
Old Mar 6, 2006 | 07:55 AM
crxY-49's Avatar
forgot to mention 2000 civic cx
Old Mar 6, 2006 | 08:56 AM
Relic1's Avatar
yes it could still be the fuse if the rest of the lights work. Basically only the cluster and climate control run off the dimmer. (ther are a few other lights but nothing you'd notice) Check the fuse first, under dash fuse box.
to bypass the dimmer, unplug it and leave it removed. (do not plug it back in with this done)
Jumper the red and black wires together. Leave the red/black wire alone.
This will set the dash lights to full on all the time.
Old Mar 6, 2006 | 09:00 AM
crxY-49's Avatar
Thank You. This should be all the information i need to trouble shoot this problem.
I checked the fuses over and over. They all seem fine.
I'll try to bypass the dimmer.
Old Mar 6, 2006 | 09:34 AM
crxY-49's Avatar
I just connected the red and black wire from the dimmer together, and the dash lit up!!
Thanks so much Relic.
I'm assuming I need a new dimmer.
Old Mar 6, 2006 | 09:36 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxY-49 &raquo;</TD></TR><TR><TD CLASS="quote">I just connected the red and black wire from the dimmer together, and the dash lit up!!
I'm assuming I need a new dimmer.</TD></TR></TABLE>
You are correct sir.
ladybender
Jun 21, 2007 10:01 PM
b_serious
Apr 28, 2007 06:58 PM
mel
12
Nov 9, 2006 09:04 AM
law_teg_92_R
Jun 21, 2005 08:37 PM
