maintance required light
Old Mar 5, 2006 | 06:38 PM
petergriffen's Avatar
Default maintance required light
ok my girlfriends mantanice reguired light is on. now i have a integra and i can clear mine, but where is the buttom at . on my integra its righ on the back of the panel you take out right by your legs while driving
Modified by petergriffen at 11:06 PM 3/5/2006
Old Mar 5, 2006 | 06:42 PM
Sliced Beard's Avatar
Default Re: maintance required light (petergriffen)
what kind of vehicle does she drive, year and model?
Your post made absolutely no sense to me.
Old Mar 5, 2006 | 07:02 PM
Default Re: maintance required light (DirtySol)
sorry its a 2002 lx
Old Mar 5, 2006 | 07:38 PM
Civic LX
there should be a button on the cluster that says select/reset, hold that down until the maint reqd light goes off. You have to push it down before you key on the ignition and hold it while turning the ignition to the RUN position, hold it for another 5-7 seconds and it should go off on its own. Once the light turns off, release the button.
very simple.
Old Mar 5, 2006 | 08:06 PM
EL Vap133's Avatar
Ask him to let you see his User Manual, you can find it in there.
Old Mar 5, 2006 | 09:05 PM
mRs_PaNdA's Avatar
disconnect the negative battery terminal
Old Mar 6, 2006 | 06:45 PM
Default Re: maintance required light (mRs_PaNdA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mRs_PaNdA &raquo;</TD></TR><TR><TD CLASS="quote">disconnect the negative battery terminal</TD></TR></TABLE>
I had a guy try that with a 93 Accord once...I wanted to laugh my *** off because it is mechanical.
drkgrnaccord96
Feb 12, 2007 03:34 PM
ROB8387
Dec 16, 2006 02:00 PM
Try2Live4God
Acura TL, RL & ZDX
Nov 30, 2005 04:21 PM
coronadrinker
Sep 27, 2005 03:45 PM
Chaze*R
Jun 2, 2002 11:50 AM
