maintance required light
ok my girlfriends mantanice reguired light is on. now i have a integra and i can clear mine, but where is the buttom at . on my integra its righ on the back of the panel you take out right by your legs while driving
Modified by petergriffen at 11:06 PM 3/5/2006
Re: maintance required light (petergriffen)
Civic LX
there should be a button on the cluster that says select/reset, hold that down until the maint reqd light goes off. You have to push it down before you key on the ignition and hold it while turning the ignition to the RUN position, hold it for another 5-7 seconds and it should go off on its own. Once the light turns off, release the button.
very simple.
very simple.
Re: maintance required light (mRs_PaNdA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mRs_PaNdA »</TD></TR><TR><TD CLASS="quote">disconnect the negative battery terminal</TD></TR></TABLE>
I had a guy try that with a 93 Accord once...I wanted to laugh my *** off because it is mechanical.
ROB8387
12-16-2006 02:00 PM
Chaze*R
06-02-2002 11:50 AM
