INJEN COLD AIR INSTAL !
Hi I just installed an Injen CAI and when I was putting it in, it siad to Remove the PVC pipe connecting the water bypass hose and vacuum line. so I did and some gree water like fluid came out, is this normal because it is the water bypass hose? anyway I conected evrything and my car starts and runs fine. just wondering if it's normal for this to happen. it wasent much water maby like 1/4 of a cup maby.
Modified by ITR_kulawik at 8:13 PM 3/5/2006
Class of 06 is off to a rocky start.
Green like fluid is hands down without a doubt Coolant. So you might wanna put that cup of coolant back in the cooling system. I do remember so coolant leakin out of the block when i changed the tube from the valve cover to the intake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hYpE-R-29 »</TD></TR><TR><TD CLASS="quote">forget the bypass valve its useless..imo..but then again i had one on
No one has made any mention of an "AEM bypass valve" for air.
</TD></TR></TABLE>No one has made any mention of an "AEM bypass valve" for air.
Driven
51
Aug 17, 2002 09:19 PM
