When you car is warmed up, does your Temp gauge read this low?
Old Mar 5, 2006 | 01:11 PM
Suprasonic's Avatar
Default When you car is warmed up, does your Temp gauge read this low?
Seems like it makes plenty of heat. I just got this car, so maybe it's normal, I dunno.
Justin
97 Accord EX 2.2L 5speed.
Modified by Suprasonic at 2:40 PM 3/5/2006
Old Mar 5, 2006 | 01:16 PM
piggiepigg's Avatar
Default Re: When you car is warmed up, does your Temp gauge read this low? (Suprasonic)
My 1994 lx reads just like that
Old Mar 5, 2006 | 01:19 PM
YeuEmMaiMai's Avatar
both of mine read lower than that.
I have a '94 LX and a '98 LX-V6
IF your car is acting wierd such as TQ converter not locking up, insufficient heat, less gas milage, then you have reason to be worried about the guage.
Even after I replaced my t-stat on my '94, the guage did not read any higher than before...........
Old Mar 5, 2006 | 01:30 PM
SuShiBoiiii's Avatar
mine is lower then that but its normal
Old Mar 5, 2006 | 01:35 PM
momstaxi's Avatar
Default Re: When you car is warmed up, does your Temp gauge read this low? (SuShiBoiiii)
i have had two 5th gen accords, both temps were at that identical spot..
Old Mar 5, 2006 | 01:37 PM
P_Adams's Avatar
That's right where you want it.
It's more important that it sits there consistantly, as opposed to wandering all over the place.
That's why almost no OEM manufacturers actually calibrate either Fuel, Temp or Volt gauges. They're almost never accurate (and it avoids all manner of piddling arguments during the warranty period)
"I want it fixed, it's reading 5 degrees low..... Wah!!!"
As long as it stays there, you've no problems.
P
Old Mar 5, 2006 | 01:43 PM
fw190bvi's Avatar
Default Re: When you car is warmed up, does your Temp gauge read this low? (P_Adams)
that is completely normal...
you reallly dont need to worry untill it gets like 3/4 of the way to the top
Old Mar 5, 2006 | 02:25 PM
Ruskimafia's Avatar
thats normal mine reads way lower then that
Old Mar 5, 2006 | 02:36 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
My original instrument cluster read lower than that. The second cluster I put in, read exactly like that. (The speedometer went bad on the original cluster.)
The gas gauges on the two clusters read differently too, so I think it depends on the gauges.
Like P Adams said, it's important it sits there consistently.
Old Mar 5, 2006 | 04:49 PM
'00Accordster's Avatar
mine reads at exactly that point
Old Mar 5, 2006 | 04:50 PM
kniob's Avatar
Default Re: When you car is warmed up, does your Temp gauge read this low? ('00Accordster)
same as mine.
Old Mar 5, 2006 | 05:15 PM
jakeiscool's Avatar
Banned
yes. thats how mine used to look with my f22b1 all the time.
Old Mar 5, 2006 | 07:53 PM
iLUVmyACCORD's Avatar
mine is alitte lower than that..
Old Mar 6, 2006 | 07:54 AM
evans's Avatar
Mine reads just slightly lower but that is normal for the 5th gen accords. does anyone know why the temp guage reads like that? i know it is normal but most other cars temp guage reads higher than that. it seems the 6th and 7th generation accord temp guage reads higher than that of the 5th gen.
Old Mar 6, 2006 | 08:01 AM
Default Re: When you car is warmed up, does your Temp gauge read this low? (evans)
i have had 3 sables and they all had temp guages that did not rise abouve 1/3 of the way. Both of my current cars are the same way they rise up only 1/4 of the way and will cook you alive on max heat........
Old Mar 6, 2006 | 08:12 AM
TouringAccord's Avatar
H-T Order of Merit
looks fine. I can't remember what my 95 EX looked like exactly, but it was around there.
The picture also looks like it was taken on a bit of an upward angle, possibly making it appear like the needle is higher than what it really is.
Old Mar 6, 2006 | 08:38 AM
accordselux's Avatar
Me Gusta History
Default Re: When you car is warmed up, does your Temp gauge read this low? (TouringAccord)
it's fine, mines about the same spot in my 6th gen.
If it starts going halfway and above, then wonder.
Old Mar 6, 2006 | 09:38 AM
wingback44's Avatar
Default Re: When you car is warmed up, does your Temp gauge read this low? (accordselux)
my 94 LX reads the exact same as that. its normal, and right where you want it.
Old Mar 6, 2006 | 11:25 AM
P_Adams's Avatar
In reality, it's reading the same 190 degree coolant temp as any other temp gauge, It's just that's where it happens to sit. And your question is precicely why they don't calibrate them and display numerical values.
The important thing to remember is it's movement.
If it's below where it normally sits, -themostat
If it's above - overheating (or on it's way)
And if you catch it moving rapidly higher than normal, pull over quick
P
Old Mar 6, 2006 | 11:39 AM
HondaAccordTdR's Avatar
Mine actually reads higher than that, just a smidgen below the mid-way line. Anything to look in to?
Old Mar 6, 2006 | 11:47 AM
accordisslow's Avatar
Default Re: When you car is warmed up, does your Temp gauge read this low? (HondaAccordTdR)
that looks about right.....mine...usually stays like 2/4ths of the way from blue to the middle....mainly like 2mm above blue lol
Old Mar 6, 2006 | 11:56 AM
P_Adams's Avatar
If it stays there day after &^%#$ day and never changes; you've nothing to worry about. It's just that because of manufacturing tolerances that point is where it chooses to display 190 degrees.
A useful tool I've had for years is a coolant temperature thermometer. It looks like a poultry thermometer, much like the one Dear Ol' Mom used to use on "The Bird"
Next Saturday, b4 you go anywhere; take off the Radiator Cap and stick one of these Coolant Thermometers into the coolant and let the engine reach operating temp. The Thermometer will confirm the operating temp of your system, and let you know just what that gauge is saying.
P
Old Mar 6, 2006 | 12:22 PM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">If it stays there day after &^%#$ day and never changes; you've nothing to worry about. It's just that because of manufacturing tolerances that point is where it chooses to display 190 degrees.
P</TD></TR></TABLE>
im hoping that thermometer creates a seal...
Old Mar 6, 2006 | 02:43 PM
P_Adams's Avatar
Default Re: When you car is warmed up, does your Temp gauge read this low? (fw190bvi)
Actually, I've never had one belch while the caps' been off. That's not to say you might not have a cup or two of fluid on your shoe from the brief thermal surge; but that's what catch bucket's are for, Isn't it?
If it does do an "Old Faithful" immitation, you're well past the temp gauge discussion and into the "why is it overheating" arena.
p
Puchito
Oct 20, 2011 08:40 AM
76 camaro car
Sep 11, 2011 04:23 AM
TooCheapToGetANewCar
Oct 18, 2007 04:08 PM
civic_jdm
Nov 23, 2006 10:09 AM
jkoshy18
Aug 27, 2006 09:33 PM
