moonroof problem
I need some help with my moonroof. For some reason it will tilt up and close but then when goes to slide back it will slide like 4 inches maybe then stops. I just need ideas of what might be wrong. the motor runs and can hear it while it is trying to slide back. I don't know if the motor/clutch thing or what. I am just confused so guys help me out please.
thanks
ryan
thanks
ryan
You have to grease the tracks up, they're dry that's why. You could also help the roof slide with your hand while you're pressing the button, thta's what i had to do until i greased it up, then it worked fine. White lithium grease works well
