TPS (Throttle Position Sensor)
Old Mar 5, 2006 | 10:52 AM
calvinx29's Avatar
Default TPS (Throttle Position Sensor)
Where is the TPS located at? How much does a used one (working) run for? new?
What is the difficulty of installation?
Old Mar 5, 2006 | 10:59 AM
sik96teg's Avatar
Default Re: TPS (calvinx29)
on the firewall side of the throttle body but if u dont know anything about it. How do you know you need one. There all over ebay for around 20 bucks.
Old Mar 5, 2006 | 06:15 PM
calvinx29's Avatar
Default Re: TPS (sik96teg)
no, i dont know anything about it, but according to this post: https://honda-tech.com/zerothread?id=224924
i'm having the same problem. Idles low and dies out sometimes. Then returns to normal. Keeps doing it every now and then, but has been doing it a lot lately.
is there a way to adjust it? or will i have to replace it?
EDIT: my axles were dead, probably due to this problem. i just replaced them so they're fine now, but may lead to axle failure again if i do not fix the tps problem.
Old Mar 9, 2006 | 04:15 AM
sik96teg's Avatar
yea u can adjust the tps if its probably riveted in then it should be good you have to use a multimeter to see what its reading if u do a search there is a write up for it somewhere i havent messed wit a tps in a while i think closed its .5 closed and wot its 4.5 or sum ****. Also what year is your car i have a bove full of tbs and tps sensors if yours is done i could hook u up
h2bv8killa
Aug 16, 2007 02:14 AM
nick1981
Apr 7, 2007 04:33 PM
98gsrTEG
Apr 17, 2004 11:12 AM
gabspeed
Mar 4, 2004 06:11 AM
Goldfingiz
Jul 22, 2003 01:26 PM
