freaking axle nut!!
Old Mar 5, 2006 | 10:48 AM
MI4$DC5's Avatar
Default freaking axle nut!!
well i couldnt get the passenger side nut to come off for anything!!! so i decided to cut it off. i have a grinder that cuts metal. Question is how would i go about cutting it off without messing up the spindles on the rotor?
Old Mar 5, 2006 | 10:51 AM
schardbody's Avatar
dont cut it off. you need a breaker bar and a long cheater pipe.
Old Mar 5, 2006 | 10:56 AM
MI4$DC5's Avatar
Default Re: (schardbody)
been there and done that already
Old Mar 5, 2006 | 11:00 AM
dohcdelsol's Avatar
Default Re: (MI4EH2)
dont cut it off
did u try locking the tranny to prevent the axles from moving then with a 6ft bar brake that bolt???
impact gun?
theres alot more ways then just cutting it.. ur gunna run into problems and mostlikely expletive up the threads and have to get a new axle
do it right the first time
Old Mar 5, 2006 | 11:03 AM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">dont cut it off. you need a breaker bar and a long cheater pipe.</TD></TR></TABLE>
Been there. Had like a 5 ft cheater bar and it snapped the breaker bar. LOL. Good thing it was Craftsman, walked in and got another one. Heat up the axle nut!
Old Mar 5, 2006 | 11:07 AM
schardbody's Avatar
heating the axle nut helps, but be careful how hot you get that area or you will destroy your wheel bearing.
Old Mar 5, 2006 | 11:08 AM
jklaudio's Avatar
get a breaker bar, and put ur whole damn jack handle on the end to extend it
Old Mar 5, 2006 | 11:14 AM
ch00dlz's Avatar
Default Re: freaking axle nut!! (MI4EH2)
I just had the same problem. Used impact gun w/150 psi max. I used a breaker bar w/ a screwdriver in the tranny. I had my fat 250 lb homeboy bounce on it (broke the breaker bar). Fed up, I took the whole hub assembly w/control arm off and my neibor used a 500psi max impact gun and zipped right off!!!
AXLES SUCK!
Good Luck
Old Mar 5, 2006 | 11:18 AM
ekcivic9's Avatar
pblaster it up
Old Mar 5, 2006 | 01:06 PM
buttascotch_3's Avatar
impact wrench my friend did mine and his was like 150 psi
Old Mar 5, 2006 | 01:21 PM
JDMISACULT2's Avatar
Default Re: (buttascotch_3)
You could always put a stong screw driver in the rotor so it stops when it hits the caliper! just what i usally do
Old Mar 5, 2006 | 01:34 PM
fmrprojects's Avatar
Default Re: (JDMISACULT2)
make sure the stake on the nut is not in and use a breaker bar. impact gun is always the easiest
Old Mar 5, 2006 | 01:44 PM
MI4$DC5's Avatar
been there and done all of that. i soaked it in PB blaster and liquid wrench for 1 week before i even started.
Breaker bars..been there. not working
im swaping my motor and i have new axles already. so ****** up the axle is the least of my worries. i just dont want to mess up the wheel bearing.
i might just go and get a whole freakin replacement.
Old Mar 5, 2006 | 01:53 PM
ch00dlz's Avatar
whoa...don't give up! Take a break or something. Are you driving it to work tommorrow or something?
Old Mar 5, 2006 | 01:55 PM
tallyturbo's Avatar
please dont cut it. i used a 10 foot breaker bar and it came right off.
Old Mar 5, 2006 | 06:43 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (tallyturbo)
heat+ breaker bar+ wd40 ..should work
Old Mar 5, 2006 | 07:00 PM
SteveoBA8's Avatar
Default Re: (BLUE EH3)
wd+1/2inch break over bar+ cheater bar+*****= loose
Old Mar 5, 2006 | 07:22 PM
BlackHXCoupe's Avatar
Default Re: (SteveoBA8)
Do it while your wheels are on the ground, have someone push on the brakes, and turn it loose. I used a small 4" long ratchet with a foot long bar that was on my Floor Jack to get it off, came off easy.
Old Mar 5, 2006 | 07:26 PM
FRAWSTY's Avatar
use a one inch breaker bar and an extension and put a fat screw driver in the rotor
Old Mar 5, 2006 | 08:04 PM
darkracer's Avatar
soak in some penetrating oil first, i prefer my snap on 1/2 impact, 800 ftlbs. will usually get it off...lol, if not, torch, then when decently hot, shoot the axle with wd40, that will cool the axle and not the nut, and contract the metal slightly, then use breaker bar, quickly.
good luck
Old Mar 5, 2006 | 08:18 PM
MI4$DC5's Avatar
Default Re: (darkracer)
my car is a ****** rust bucket. imma just replace the whole thing cause it looks like **** anyways
Old Mar 6, 2006 | 07:39 AM
turboeg_4's Avatar
hmm... did you forget to uncrimp the nut? I know on my 93 hatch you have to make an indent on the nut to make sure it doesn't come off-- maybe you over looked this? Also, I agree that this should be done while the wheels are on the ground-- it was a bit easier for me this way.
Old Mar 6, 2006 | 08:27 AM
Royal_C!ty's Avatar
Default Re: freaking axle nut!! (turboeg_4)
try an impact gun
Old Mar 6, 2006 | 10:20 AM
Chong's Avatar
ballin
Default Re: freaking axle nut!! (eg8kid)
If you used a 1/2" Drive rachet handle w/ a breaker bar over it, the rachet handle will snap at the part where it connects the socket. Try a bigger size drive w/ the breaker bar. And grow some muscle.
Old Mar 6, 2006 | 10:34 AM
db8gsr_teg's Avatar
same thing happen to me, broke my breaker then got frustrated. next i use an impact gun on 150 psi or more and that nut just came out.
