b18b1 into a 99 civic si
Old Mar 5, 2006 | 09:44 AM
boostedB18B1's Avatar
Default b18b1 into a 99 civic si
Im pretty new in the honda scene and i wanted to know if there is anybody out there that can tell me what im going to need to swap a 95 b18b1 into a 99 civic si. if there is any body out there that can help me iwould appreciate it if you could get back to me at
bachmeier0317@yahoo.com
Old Mar 5, 2006 | 09:50 AM
E_F_9's Avatar
Is there not a motor in it anymore?I would rather have the b16 in it
Old Mar 5, 2006 | 09:52 AM
onnoff7's Avatar
yea. keep the si motor.
Old Mar 5, 2006 | 09:57 AM
RaceMyGhost's Avatar
Default Re: (onnoff7)
if you have the b16 head, swap in the b18block and slap on the b16 head for a ls/vtec conversion.
Old Mar 5, 2006 | 10:36 AM
Default Re: (jdmef9si)
the motor is still in perfect running condition but i found a fully built b18b1 thats been set up for a turbo and i wanted to swap it into my car.
Old Mar 5, 2006 | 12:17 PM
E_F_9's Avatar
do ls/vtec turbo then
Old Mar 5, 2006 | 02:42 PM
watsvtecEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmef9si &raquo;</TD></TR><TR><TD CLASS="quote">do ls/vtec turbo then</TD></TR></TABLE>
Old Mar 5, 2006 | 02:46 PM
Lauj87's Avatar
i don't know the laws in the state that you live in but...in california if you want to stay street legal your going have to swap a 99 motor or newer inorder to have your car smogged.
If you do go with this setup i'd say LS/Vtec/TUrbo :-D all the beauties of honda in one :-D.
Old Mar 6, 2006 | 06:36 AM
Azndr3amboi@yahoo.com's Avatar
Default Re: b18b1 into a 99 civic si (boostedB18B1)
swaping b18 to a 99 si i think its a waste of money. b16 is good enough i would add a turbo to it...
Old Mar 6, 2006 | 07:17 AM
jdmotorsports's Avatar
Default Re: b18b1 into a 99 civic si (Danhphan04@hotmail.com)
well, it realy depends. if its a fully built engine, you can get more out of it then the stock b16. you would need to convert EVERYTHING. crank angle sensor, all smog sensors. it can be done.
Old Mar 6, 2006 | 07:49 AM
integra racr04's Avatar
fully built or not, its the vtec man...stay with the B16, unless you got the money for a ls/vtec/turbo setup, like everyone else on here suggested...BTW....you got any pix of your SI....
Old Mar 6, 2006 | 07:58 AM
Default Re: b18b1 into a 99 civic si (integra racr04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra racr04 &raquo;</TD></TR><TR><TD CLASS="quote">fully built or not, its the vtec man... </TD></TR></TABLE>
no, no its not. why do people think vtec is gods gift to mankind?
a fully built b18 engine will hold 2x the boost a b16 can. sure if your talking stock vs stock, but were not. he said the engine is setup for turbo, that to me means forged internals, iron sleeves, maybe cams and valves, port and polish. with a properly setup engine the b18 will have alot more horsepower and alot more torque then the b16 will.
Old Mar 6, 2006 | 03:27 PM
Shaun's Avatar
Default Re: b18b1 into a 99 civic si (jdmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">
a fully built b18 engine will hold 2x the boost a b16 can. sure if your talking stock vs stock, but were not. he said the engine is setup for turbo, that to me means forged internals, iron sleeves, maybe cams and valves, port and polish. with a properly setup engine the b18 will have alot more horsepower and alot more torque then the b16 will.</TD></TR></TABLE>
this is true..we dont know whats done to the LS.... when swaping the ls into the SI you will need the integra rear mount, and swap the b16 upper timing belt mount onto the b18
Old Mar 6, 2006 | 06:16 PM
Default Re: b18b1 into a 99 civic si (Shaun)
you must know your hondas shaun. you are correct. the following is a list of the mods on the motor: forged,micro polished, knife edged crank, smr forged h beam rods, acl high flow main bearings, and rod bearings, 84mm 8.5:1 wiseco dished and coated pistons. the block has been honed, decked, and hot tanked, and sleeved.there is a brand new head w/ a stage 3 port and polish 10,000 rpm revhard springs, stage 3 turbo cams, custom turbo manifold, the intake manifold has beenported and polished to 71 mm. it also has a high flow oil and water pump. o three layer metal head gasket. i was told by several different engine builders that the motor was cabable of safely boosting to 25 pounds. with a 150 shot of nitrous the motor should easily be able to produce 500 hp to the wheels give or take.with a heavy duty stage 3 clutch,possibly a multi disc but i dont want to go too crazy and loose any possibility of the car being a daily driver. i know im gonna need to up grade the axels, swap an ls tranny in w/ the motor, and use the integra rear mount but, i dont know what else im gonna need and how to go about the swap so if you could aks someone to help i would forever be in your debt because i really want this swap to happen. ive never owned a turbo car bofore so right now i need all the help i can get please help me transform my civic!!!!!!!!!!!!!!!
Old Mar 6, 2006 | 06:29 PM
IntegraLova's Avatar
Sounds good except the part about swap in an ls tranny.The si tranny is fully compatible with the b18b and is lightyears shorter geared.Ofcourse the highway driving issue comes in with the b16 tranny.IMO i would trade the b16 tranny for a gsr tranny and have a good balace.Short gears but not too short.Just my .02
Old Mar 6, 2006 | 06:33 PM
DoctorGSR's Avatar
i would much rather have a fully built LS than a stock b16. Keep the b16 tranny, swap the LS motor, and go have fun at the track.
Old Mar 6, 2006 | 06:34 PM
posHonda's Avatar
b16 tranny in a strong LS turbo is hell in 1st and even 2nd...better have LSD and good tires/slicks
Old Mar 6, 2006 | 06:36 PM
Ghettokracker71's Avatar
Default Re: (DoctorGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoctorGSR &raquo;</TD></TR><TR><TD CLASS="quote">i would much rather have a fully built LS than a stock b16. Keep the b16 tranny, swap the LS motor, and go have fun at the track. </TD></TR></TABLE>
Agreed!
Old Mar 6, 2006 | 08:00 PM
e-honda's Avatar
Default Re: (Ghettokracker71)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghettokracker71 &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed! </TD></TR></TABLE>
agreed x2 With that setup what are u waiting for man.
Old Mar 7, 2006 | 05:53 AM
DC4love's Avatar
fully built ls is way ******* better than a stock b16
decon
20
Dec 24, 2012 05:08 AM
kt_34
Jan 10, 2009 08:33 PM
MW325
Aug 5, 2006 12:44 PM
94blackb18b
Jun 29, 2003 09:03 PM
