b16a2 good compression with a leaking head gasket.
Old Mar 5, 2006 | 08:48 AM
spidermancivic's Avatar
Default b16a2 good compression with a leaking head gasket.
just did a compression test on my 99 civic si b16a2 with a leaking head gasket. numbers came out 200-199-200-195. i did the comp test correctly 3 times. same numbers. did not drop oil in the cylinders though.
i thought the compression was supposed to be uneven or low if i had a leaking head gasket? head gasket is leaking and losing about a quart of oil every 900-1000 miles, no overheating, and burns a little smoke on startup and early morning cold idles. no oil in coolant either.
gonna pick up some arp studs and a new oem head gasket wednesday before slapping the t3/t4 on. any feedback with the comp numbers and head gasket leak would be greatly appreciated.
Old Mar 5, 2006 | 11:12 AM
Ruben19's Avatar
do a leak test............
nate1229
Nov 8, 2014 12:10 AM
gsrHB
May 4, 2007 03:38 PM
skUnK2jdm
Jan 30, 2007 05:36 AM
P@@RB@Y
Jan 20, 2006 01:19 PM
Evs-One
Mar 3, 2003 01:09 AM
