problems taking off gsr spoiler.
i have searched.
when i am taking off my gsr spoiler from my 94 gsr.
there is a wire for the brake light.
how can i take that out ????
i already unbolt the other 4 bolts.
sry for being so noob.
hmm, anyone have any pics of their process ???
also, i saw people buy a little black plastic thing to cover the hole,
where can you get those instead of buying off the dealer ? thanks
just unplug it and stuff it in your hatch, if your worried about it moving stick some 3M electrical tape around it and tape it to the inside of your hatch, worked fine for me.
It's real easy. Open hatch, and look underneath. There's a plastic finish panel, take a flat head screwdriver or other flat prying tool, put the tool in between the hatch and panel, and work it open. Theres metal spring type clips that will pop free once you've started the process. Once you've pulled the panel back, you'll see a wire with a plastic connector clipped to the hatch, you can't miss it. Unplug the clip and pull the wire through the hatch.
If you dont want to have the holes welded up, and painted, a cheap way to fill the holes is by putting a piece of tape under the hole and filling it with silicone, or some sort of 2 part epoxy. Good Luck
hey i just tried, which part do i take off from the hatch ??
may you take a pics and circle it please !! thanks for all your help !
look bro its the big *** plastic piece on the hatch on the inside of the car. Its the cover thats covering the wire you need to disconnect. theres no way your going to pull the wrong piece. i hope
