do you have to buy rod bearings from honda?
someone told me that bearings from napa will not work, and that the bearings are color coded and you have to match the color codes up with the bearings from honda or some bs.
i just built a d16z6 and im putting it in my today, i heard about this and it upsets me. i bought a clevite rebuild kit from napa, i dont understand why it wouldnt work if they sell it. the plasti gauge tolerances came out perfect. i just hope they will work because there is no way in hell im tearing this motor apart again!!!!
thanks.
thanks.
it all comes down to tolerances. if u know how to use the plastigage and it came ok. then ur cool. Most ppl just use green in all bearings and their engine runs fine.
YOU JUST HAVE TO CHECK TOLERANCES ALWAYS
But there really are color codes and matching.
If you search the forum you ll find what you need to know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nuno EuroVTi »</TD></TR><TR><TD CLASS="quote">it all comes down to tolerances. if u know how to use the plastigage and it came ok. then ur cool. Most ppl just use green in all bearings and their engine runs fine.
hey i appreciate your quick response. this just seems kind of shady that its not in the haynes or anywhere else about this. this was my first time doing plasti guage, my roomate who is experienced helped me out though. but when i did it it seemed like such a crappy way of measuring, that color gauge just doesn't seem precise. but from what i know they are in spec. im just wondering if this is something that honda does to keep their products bought from the dealership, just like torque-to-yeild bolts, which i have reused before.
so i guess using green is just like the normal tolerance? thanks a lot.
Main Bearing thickness by color
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785”
Red 1.995-1.992 mm 0.0785”- 0.0783”
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586”
( from https://honda-tech.com/zerothread?id=884589 )
Is that white grease on the beam side of the rod bearing bore? Both the bearing and the crankpin need to be completely dry of any oil (or grease) before you check with plastiguage or your readings will be false, specifically they will show that they are tighter than they actually are. Your bearing clearance may be excessive if what I am seeing is correct.
EDDIEONETIME
May 13, 2008 08:47 PM
92ehatch
11
Feb 17, 2008 12:42 AM
