Changing rear discs...wheel bearings?
Old Mar 5, 2006 | 06:40 AM
P@@RB@Y's Avatar
Default Changing rear discs...wheel bearings?
When I change out my rear discs how can I tell if the wheel bearings are still good?The guy at the autoparts store said th ehub assb. had to be pressed on to the rotor, but I just slid it on there no problems.
Also is there a certain ft. lbs. the hub bolt needs to be tourqed down to?
Old Mar 5, 2006 | 07:00 AM
P@@RB@Y's Avatar
Default Re: Changing rear discs...wheel bearings? (P@@RB@Y)
bumpy
Old Mar 5, 2006 | 09:41 AM
P@@RB@Y's Avatar
bumpy
Old Mar 5, 2006 | 09:45 AM
non-VTEC's Avatar
you dont need to replace your rear wheel bearings when replacing rotors.
just buy new rotors.
Old Mar 5, 2006 | 07:43 PM
Johnny_Rocket's Avatar
Default Re: Changing rear discs...wheel bearings? (non-VTEC)
Was there any vibration or humming noises comming from the rear of the car before you had to change the brakes? if not then I wouldn't worry about it because when the wheel bearings go, you'll know
Also, there should be a phillips head screw holding the rotor on the wheel bearing assembly... just take that screw out and swap rotors
Old Mar 6, 2006 | 01:04 PM
P@@RB@Y's Avatar
Default Re: Changing rear discs...wheel bearings? (JohnnyH)
No not really.Theres a sound on the highway but it sounds like tire noise.
Old Mar 6, 2006 | 01:34 PM
nitrofish420's Avatar
You can spin the hub by hand and listen or feel for any roughness or play.
Davi_Vtec
Feb 16, 2013 08:28 AM
kornerk12
Jun 10, 2007 10:30 AM
redman223
Apr 30, 2007 02:36 PM
valve79
Oct 26, 2004 01:51 PM
pbcdb
Mar 12, 2004 09:11 PM
