Clutch Problem Or Transmission
Hi, my 95 honda accord's clutch is down quiet a bit then it is normally.. it seems like it decreased by half way.. it is harder for me to shift gears and things like that.. can i get some info as to wuts wrong with it .. like if i need more clutch fluid. or is it trans problems.
Thanks
Thanks
It's all clutch. Your Transmission is NOT contributing to this.
I would first chech that you haven't run low of clutch fluid for the hydralic release mechanism. If you find the fluid reservoir dry, replenish it and bleed the system of any air (just as you would a brake system (Bleeder's at the slave cylinder).
If the system responds and you now have a hard/high pedal, you may need to go no furthur.
If you have no response, and the pedal still catches too low, you have a bad clutch pressure plate. The large diaphram spring has failed. Repairs will (of course) require the tranny be yanked, and a new clutch be installed.
P
P
