Brake booster
Old Mar 5, 2006 | 03:26 AM
M15's Avatar
M15
Default Brake booster
I just wanted to know what are the symptoms of a bad brake booster.
Old Mar 5, 2006 | 05:47 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: Brake booster (M15)
If you step on the brakes and the idle drops dramatically then its most likely the booster or the MC.
Check the booster by letting the car idle and spray carb cleaner around every seal on the booster. If the idle drops then jumps back up then thats your problem.
Good luck
Old Mar 5, 2006 | 09:33 AM
RCautoworks's Avatar
High and Hard pedal
Old Mar 5, 2006 | 10:17 AM
M15's Avatar
M15
Default Re: Brake booster (90blackcrx)
Pedal is really hard, I thought it was the brake booster because I have replaced everything else . Well I have a 13/16 MC and wanted to know what master cylinder I could use other than the CRX one that would help out.
Old Mar 5, 2006 | 10:23 AM
downest's Avatar
There are a few MCs that fit. I used the 15/16" from an 88 Prelude 2.0 Si, bolts up but you have to bend one line a little bit. There's an accord one that fits perfectly, idk which one though. If you are replacing both the booster and the MC, get them both from a DA teg (non-ABS).
15/16" MC upgrade
and on my webspace there are some pics of the MC install.
Old Mar 5, 2006 | 10:38 AM
M15's Avatar
M15
Default Re: Brake booster (downest)
Well I've already got the MC installed, I did that a long time ago now it's time to get a new Booster, I'll see if I can get one off of a teg, I'll prolly just get it from Autozone, if I can't find anything really cheap on Here. at least that way Iget a lifetime warranty.
ronstrong1983
May 23, 2013 09:35 AM
project91crxsi
10
Sep 21, 2009 04:54 PM
slipperyduck
10
Jul 11, 2004 11:42 AM
snoop_bealybob
Oct 18, 2002 04:49 AM
