heater problems
Old Mar 4, 2006 | 08:40 PM
typeRaccord's Avatar
Default heater problems
hey guys, i just baught me an EK....year 98 and my heater is out, it just blows cold air....I need some help on what the possible problems could be, any help will be greatful, thanks a lot. Bare in mind, i'm new to an EK...so i might not know where some things are, if you could just step by step explain to me if you got time on ur hands, thanks a lot
Old Mar 4, 2006 | 08:44 PM
Syndacate's Avatar
check ur heater core, it sounds as though it's not operational, or there might be a blockage inside it
Old Mar 4, 2006 | 08:54 PM
graveltravel2's Avatar
heater coreeee.
replace.
the only thing is , i dont know if you can replace it without taking the dash out or not. hummsss.
Old Mar 4, 2006 | 09:01 PM
NesaiTuner's Avatar
Default Re: (graveltravel2)
you can take it out if your gumby sorry to say it but the dash has to come out. Is that the only thing though? your cars not over heating or anything else. there are a lot of reasons why your heater wouldn't work. check your fluids in your radiator too before you decide to rip out the dash. I've found that for some reason if you're low on coolant, your heater will blow cold and your car will not over heat...weird but it's happen to me. so check that. If that seems ok then most likely it is your heater core. good luck with that. it's located behind your dash on the passanger side... up behind the glove box. Good luck with it
Old Mar 5, 2006 | 12:27 PM
Default Re: (NesaiTuner)
hey, much appreicated it, all responses are great, i'll take a look into it
tollickj
Dec 24, 2013 04:25 PM
Apexiracer
Nov 7, 2009 06:01 PM
ghettochild
May 19, 2009 06:03 AM
Josue
Oct 21, 2005 07:43 AM
lonefuzzy79
Oct 8, 2003 12:37 PM
