GSR Idles high when cold...???
Old Mar 4, 2006 | 08:28 PM
RegCRVtec's Avatar
Default GSR Idles high when cold...???
Its a 97 GSR Sedan and it has the following mods on it... Intake, DC headers, catback exhaust, skunk2 int manifold, underdrive pulleys, 250 LPH fuel pump, and ITR ECU...
The problem is.. when you first start the car when it's cold, it idles between 2000 and 2500, and as it warms up it slowly drops down to about 700... but that's after with warmed up to operation temp. It doesn't fluctuate at all.. It only does it when it's cold.. after it's been sittin for a while. Then I never have any problems...
Any suggestions?? it doesn't surge as if there were a vacuum leak.. so I dont believe that would be it... but it's highly annoying..
Thanks in advance...
Old Mar 4, 2006 | 08:32 PM
sik96teg's Avatar
Default Re: GSR Idles high when cold...??? (RegCRVtec)
it should idle high for a few minutes when cold. if it was a wierd idle id say it was the iacv or air leak
Old Mar 4, 2006 | 10:55 PM
no2unenolife's Avatar
sounds fine to me
Old Mar 4, 2006 | 11:18 PM
iBear's Avatar
Default Re: (no2unenolife)
Sounds normal.
Old Mar 5, 2006 | 12:04 PM
DC2_005200's Avatar
yea that is normal, GSR's run like **** if you try to drive them cold. The high idle is the ECU trying to get the car to normal temperature so you dont waste a lot of gas when the car is cold...
Old Mar 5, 2006 | 12:06 PM
jomama's Avatar
sounds fine, just as long as it comes down by the time it's warmed up
Old Mar 5, 2006 | 12:25 PM
vincepru's Avatar
normal... dont worry about it, just wait for it to drop before you start driving, or else say bye bye to your gas
Old Mar 5, 2006 | 06:58 PM
Sam92Teg's Avatar
Default Re: (vincepru)
Not sure about your GSR, but on my 92 RS a Fast Idle Thermo Valve creates a vacuum leak at the throttle body on purpose to raise the idle until the car warms up. I just wonder if there is any way to adjust it to bring the 'fast idle' down a tad.
Old Mar 5, 2006 | 07:02 PM
TRE_'s Avatar
Default Re: (Sam92Teg)
sounds fairly normal to me
Old Mar 5, 2006 | 07:19 PM
Promina's Avatar
I had the same problem, but I got a friend to check it out and he messed with the fast idle and now it starts at a cold idle of 1500 and settles down to 700 when warm.
Old Mar 5, 2006 | 07:45 PM
Cova85's Avatar
For me it jumps to 2000 and in 5 seconds it drops to 1500 then goes lower until about 700ish when its warm. So its probably good.
Old Mar 5, 2006 | 08:00 PM
xplanetearth420x's Avatar
Default Re: GSR Idles high when cold...??? (Cova85)
my 95 gsr does the same thing but it only idles a 1500
its completely normal
Pezgoon
43
Oct 24, 2014 03:27 AM
JJexpress
May 19, 2009 03:16 PM
LShatchie
Apr 3, 2005 04:40 PM
90-CRXSi
Nov 18, 2002 06:35 PM
