iacv wtf tried everything
Old Mar 4, 2006 | 08:09 PM
crv-techu's Avatar
Default iacv wtf tried everything
getting power to iacv from ecu can't find break in wire cleaned with brake clean and barrowed a friends iacv but nothing still code 14 just need to pass emissionsthis is driving me crazy
Old Mar 4, 2006 | 08:40 PM
sik96teg's Avatar
Default Re: iacv wtf tried everything (crv-techu)
What exactly is the prob
Old Mar 5, 2006 | 11:28 AM
crv-techu's Avatar
Default Re: iacv wtf tried everything (sik96teg)
problem is that everything seems to working the iacv works when connected to a 12v source and the wiring harness is getting the correct voltage 8 ohms and i cant find a break in the wire
Old Mar 5, 2006 | 11:43 AM
dohcMONSTER's Avatar
it's not grounded out right, check the ground on the thermostat. I had the same problem and thats what it ended up being
Old Mar 5, 2006 | 12:34 PM
sik96teg's Avatar
Default Re: iacv wtf tried everything (dohcMONSTER)
yea try goin thru and cleaning up your grounds.
Old Mar 5, 2006 | 02:54 PM
crv-techu's Avatar
wouldn't other things be not working if it wasnt grounded properly the wires on the thermostat are tight and seem to be ligit any other suggestions thanks for answering my threads guys i need all the help i can get when its electrical problems
Old Mar 5, 2006 | 03:05 PM
sik96teg's Avatar
WHATS IT READING AT THE ECU
Old Mar 5, 2006 | 07:52 PM
crv-techu's Avatar
does anyone have a pin out for an obd1 vtec ecu i have a JUN chipped p72 ecu i need to know where the pin in the ecu is for the iacv preferable the wire end female plug
Old Mar 6, 2006 | 03:19 PM
sik96teg's Avatar
damn dunno do a search there should be one on here somewhere
Old May 12, 2006 | 07:43 PM
god.loves.ugly
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crv-techu &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have a pin out for an obd1 vtec ecu i have a JUN chipped p72 ecu i need to know where the pin in the ecu is for the iacv preferable the wire end female plug</TD></TR></TABLE>
SiR Inspired ED7
May 6, 2008 08:24 PM
crv-techu
Mar 4, 2006 01:35 AM
