2000 GSR crank flux sensor OBD2 ECU
Old Mar 4, 2006 | 05:43 PM
jdmlove's Avatar
Default 2000 GSR crank flux sensor OBD2 ECU
Not too long ago My car started going into limp mode, and no check engine light came on...
unfortuneately I bought a car that was lacking a CEL...
Anyways, I could just restart the car to solve the problem quickly, but after speaking to the previous owner he said it was the sensor that was the problem.
I replaced the sensor, and reset everything...
all is well for a few days, and now it randomly jumps into limpmode...then later on in the day when I go to drive my car again its fine...and it will go back into it at random times...
so did i miss somthing, someone told me i'd have to remove the timing belt and apparently I didnt have too, because I swapped sensors without the belt coming off...
anything else i might wanna check? the magnet on the gear, any way to correctly reset the ecu...etc..?
any input would be much appreciated
Old Mar 5, 2006 | 11:46 PM
jdmlove's Avatar
up
krisfnbs
Honda Civic (2001 - 2005)
30
Jul 5, 2024 03:30 PM
cheeks97R
Apr 17, 2005 09:22 AM
MaWeiTao
Dec 20, 2004 01:41 PM
i-CiViC
Sep 25, 2004 06:28 PM
