Crazy weird oil leak b18
Okay i have had this problem for a very long time and i can not find it out. My transmission gets covered with oil on the top when i drive for a short period of time. Everynight i clean it off and the next day it comes back. The seal between the head and block is good, no oil there. Just the top of hte tranny is getting wet with oil. Any ideas?
possibly the seal inside the trans? Does your clutch start to feel soft after you drive awhile? Could be oil getting though the seal and the clutch spinning it off. Otherwis check your valve cover gasket and cam plugs they could be leaking too. Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegman85 »</TD></TR><TR><TD CLASS="quote">check around your vtec silenoid, i had a leak there because of the gasket and it would leak down the block onto the tranny.</TD></TR></TABLE>
+1 i had the same problem..easy fix
wootcivic
Apr 1, 2005 11:54 AM
