turbo xs dual stage not working
Old Mar 4, 2006 | 04:41 PM
crxvtecturbo's Avatar
* B A N N E D *
Default turbo xs dual stage not working
i have a dual stage turbo xs boost controller and when i try to set up the first stage and try to unwind the screw after a couple turns it starts pushing out air pressure but when i wind it in it goes away i have the blue nipple to waste gate and brass to vaccum block do you think it could be defective
Old Mar 4, 2006 | 09:39 PM
a1320addict's Avatar
Default Re: turbo xs dual stage not working (crxvtecturbo)
i'd double check everything is installed properly. http://www.turboxs.com/faq/turboxsdual.htm
Old Mar 5, 2006 | 02:17 PM
* B A N N E D *
Default Re: turbo xs dual stage not working (yehiknowrite)
i checked everything but i was told today that i can put teflon on the adjusting screw will that help
Old Mar 5, 2006 | 06:51 PM
sounds good...good luck
Old Mar 6, 2006 | 09:28 AM
dome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxvtecturbo &raquo;</TD></TR><TR><TD CLASS="quote">i checked everything but i was told today that i can put teflon on the adjusting screw will that help</TD></TR></TABLE>
good luck with putting teflon on that little *** screw.
Old Mar 6, 2006 | 09:39 AM
ramrod's Avatar
Default Re: turbo xs dual stage not working (dome)
when i turn mine out it makes a similar noise when "unwinding" the adjustment screw, and it works fine
oneludesol
Jul 8, 2007 10:55 PM
Hyaboosta
Feb 24, 2005 05:41 AM
Sassafrass
Mar 17, 2004 12:38 PM
99blusi
Feb 7, 2004 08:36 AM
