block build
Old Mar 4, 2006 | 03:39 PM
MAPU's Avatar
Default block build
ok, started building my motor(lsvtec). bored the block .25 over and also got os pr3 pistons. crank installation went good but then it came to the pistons. everything measured up good, but it went in hard for some reason. so i took the piston back out. now theres a gouge in the cylinder wall about .008 deep. damn. i also found out it was the second piston ring rubbing up on it. now heres my question, since i bored it out .25 over, could i just hone it till it gets smooth and install the piston, or get a new block. much help is appreciated. thanx
Old Mar 4, 2006 | 03:54 PM
NJIN BUILDR's Avatar
Default Re: block build (MAPU)
Sounds like new block or .5mm and aftermarket piston.
Glenn
Old Mar 4, 2006 | 09:27 PM
mnskateboarder's Avatar
Default Re: block build (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like new block or .5mm and aftermarket piston.
Glenn</TD></TR></TABLE>
^ yep
Old Mar 4, 2006 | 09:51 PM
MAPU's Avatar
Default Re: block build (mnskateboarder)
dammit, i knew it, i guess ill have to get a new block. thanx for the replies guys.
cherryredcivic
Nov 22, 2011 06:13 AM
black99x
15
Aug 10, 2006 03:06 PM
SnOOpY-NO
Jan 12, 2005 08:09 AM
IMPORTant Si
Oct 28, 2004 01:44 PM
