lowerd. uneven?
Old Mar 4, 2006 | 11:38 AM
zacatkings's Avatar
Default lowerd. uneven?
i put some lowering springs on yesterday. i finally got out to look and the drivers side looks good. the passeger side (this being just the fronts compared, rears are fine) looks higher. has anyone had this problem and how do i fix it or will it even out? help
Old Mar 4, 2006 | 11:48 AM
Civicse's Avatar
Default Re: lowerd. uneven? (zacatkings)
thats just the way it goes with springs sometimes. lots of ppl have this problem.
Old Mar 4, 2006 | 11:52 AM
zacatkings's Avatar
Default Re: lowerd. uneven? (Civicse)
is there anything i can do to fix it?
Old Mar 4, 2006 | 11:56 AM
Civicse's Avatar
unless you have coilcovers i don't think you can, you could do it the oldschool way and heat up the springs that sit higher with a torch. it takes some of the tension out of the spring, but i wouldn't trust that method for accuracy. there should be threads on this so do a search first. it can' be that noticeable can it?
Old Mar 4, 2006 | 12:07 PM
voltronR34's Avatar
Are they cheap springs or a quality brand? Did you buy them new or used?
Old Mar 4, 2006 | 12:09 PM
zacatkings's Avatar
Default Re: lowerd. uneven? (voltronR34)
they are dropzone ones new for real good deal
Old Mar 4, 2006 | 02:14 PM
8520's Avatar
Same way with my sol. My right front is down about 6 thread more than the driver side to make the car even.
That guy return the tranny yet?
Old Mar 4, 2006 | 02:16 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: lowerd. uneven? (got_no_sol)
dropzone are cheap
Old Mar 4, 2006 | 02:19 PM
dreww..'s Avatar
Default Re: lowerd. uneven? (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">dropzone are cheap</TD></TR></TABLE>
Says it all right there
Old Mar 4, 2006 | 02:23 PM
frankenstienEk's Avatar
Default Re: lowerd. uneven? (dreww..)
normally cheap spings or coilovers will give you those results
Old Mar 4, 2006 | 02:59 PM
Spoon-EK9's Avatar
Default Re: lowerd. uneven? (frankenstienEk)
first of all, since driver side is heavier, the car will be lower on driver side.
Second of all, you gotta wait about a week or so for the springs to settle in.
so wait and see if the car is like that after a few weeks.
BTW it's totally normal, so don't worry. your car won't flip or anything
Old Mar 4, 2006 | 07:24 PM
EGchicSOHC's Avatar
Default Re: lowerd. uneven? (Spoon-EK9)
I' VE SEEN IT TAKE UP TO A FEW MONTHS FOR SPRINGS TO SETTLE, IT MIGHT HELP IF YOU JUST PICK UP A FAT BITCH AND DRIVE AROUND FOR A WHILE!!!!!!!
Old Mar 4, 2006 | 07:41 PM
95jeremie's Avatar
Default Re: lowerd. uneven? (EGchicSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGchicSOHC &raquo;</TD></TR><TR><TD CLASS="quote">I' VE SEEN IT TAKE UP TO A FEW MONTHS FOR SPRINGS TO SETTLE, IT MIGHT HELP IF YOU JUST PICK UP A FAT BITCH AND DRIVE AROUND FOR A WHILE!!!!!!!</TD></TR></TABLE>
funny lol haha
Old Mar 4, 2006 | 07:42 PM
95jeremie's Avatar
Default Re: lowerd. uneven? (95jeremie)
but realy i have dropzone coil and they are cheap (parents got them for me)
but good luck after a few weeks
Old Mar 4, 2006 | 08:43 PM
lonefuzzy79's Avatar
Hey Zac, I bought your Si tranny off NWStreetracing.com. Anyway, drop springs usually drop a car lower in front and a bit less in the rear, the only way to even it out, get some coilover sleaves, Omnipower are great, I have them on my hatch, and they are cheap. You can get them through Titan Motorsports or I can order them for you if you call my shop http://www.pdxtuning.com
Old Mar 4, 2006 | 09:02 PM
wwang924's Avatar
Default Re: (lonefuzzy79)
My eibach pro kits are doing that..... and they were dropped evenly before regarding the left and right side. But after i was doing a swap and had the driver side jacked up for a long duration and now the passenger side is lower than the drivers side. So what did i do? i jacked up the passenger side hahaha hopefully this will work.
Old Mar 4, 2006 | 09:07 PM
zacatkings's Avatar
Default Re: (wwang924)
thank you everyone for the input. i drives fine so im not too worried about it.
Alex Nico.JDM
Suspension & Brakes
12
Oct 29, 2012 06:47 PM
b0yg0tskills
Honda Civic (2001 - 2005)
May 30, 2007 02:31 PM
Thanks knightsport!
Dec 1, 2005 04:46 PM
