obd0 motor in obd1 car...repinning the dizzy? injecotrs?
if i buy a obd0 b16 longblock and a hydro tranny, could i run the dizzy by repinning the plug to be obd1 compliant? or even hard-wiring it? do the injectors work with my obd1 harness?
You'll need an obd1/2 distributor..You cant run a obdo dizzy with an obd1 ecu if thats what you're asking..As far as the injectors, obd0 are peak and hold so you'll have to wire in a resistor box (you can get one from 88-91 mpfi car,90-91 integra,etc..) or just use some obd1 saturated injectors..
the injector clips are different on the OBD1 harness and won't plug into the OBD0 injectors - easiest to just swap injectors rather than clips
lilsicsoul
Jan 22, 2009 09:31 PM
mengy007
Oct 28, 2004 09:38 AM
