94-95 vs 96 and up..
Old Mar 3, 2006 | 11:26 PM
Kentagious's Avatar
Default 94-95 vs 96 and up..
So my GS-R got stolen a few weeks ago and I need to buy a new one now. But i want a 94-95 model because there are less emission regulations...but its hard to find a nice one and I've seen alot of the 96 and up models...I want to do a single stage vtec crossover with the ECU...but I'm told that if I do that I wont be able to pass emissions...how do I get around that if I buy a newer one? Any help would be apriciated!!!
Thanks
Old Mar 3, 2006 | 11:28 PM
.xcalibur.'s Avatar
If you get a 96+ model, just convert to obd1 and use a chipped P28 ecu or keep it obd2 and use a P73.
Old Mar 4, 2006 | 03:40 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (.xcalibur.)
The OBD1 conversion will work, as it allows for subsequent chipping. You will need an OBD1 P72 (p/n 37820-P72-A01) ECU to work the IAB system. The P28 does not have the extra transistor to work the IAB and it also lacks a knock sensor board. The OBD2 P73 will not work well with a stock GSR engine due to the difference in VTEC crossover and the missing IAB capability. OBD2 ECUs are not easily chipped. Keep in mind that you can wire an external RPM switch to work the IAB system.
Old Mar 4, 2006 | 08:55 AM
.xcalibur.'s Avatar
When he said single stage vtec crossover, i was under the assumption that he wasnt gonna have the the gsr manifold anymore eliminating the secondaries. Skunk2 does come with a CARB number making it smog friendly.
myallmotoreg
Apr 22, 2013 11:09 AM
all4imports
Jun 29, 2009 02:22 PM
baulum
May 7, 2009 10:37 PM
venessEK
Mar 14, 2008 10:03 AM
fatalman
Dec 22, 2003 06:50 PM
