Door Lock Problems..
Old Mar 3, 2006 | 11:25 PM
zoolander's Avatar
Default Door Lock Problems..
I changed out my pass. side, exterior door handle. The one i bought was from a junkyard and was the model w/o the key hole. The one that was one the car previously had one, so i just disconnect the rod that connects to the locking mechanism. Everything was working fine, all installed, and then i closed the door, and now it won't unlock and i can't open the door. any ideas?
Old Mar 4, 2006 | 02:31 AM
john666's Avatar
Default Re: Door Lock Problems.. (zoolander)
probably just have to open the door panel up again and see if the rod came loose or was installed incorrectly.
Old Mar 4, 2006 | 07:11 AM
96dxpower's Avatar
Default Re: Door Lock Problems.. (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">probably just have to open the door panel up again and see if the rod came loose or was installed incorrectly.</TD></TR></TABLE>
bingo
Old Mar 4, 2006 | 07:05 PM
zoolander's Avatar
Default Re: Door Lock Problems.. (96dxpower)
the panel is still off. all the rods are connected, but the part on the lock that moves up and down to actually lock it, won't go down all the way. Not sure what happened??? It was working fine after i switched the door handle/lock, then one time i closed it, it wouldn't unlock. perplexed???
Old Mar 4, 2006 | 08:11 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
https://honda-tech.com/zerothread?id=1548173
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INVALID &raquo;</TD></TR><TR><TD CLASS="quote"> If you can't pry out the joint w/o breaking it there are two methods to go about getting the door handle off. You can remove the three screws on the side of the door (they hold in place the door lock) and lift the rod up more to be able to unscrew the handle from the rod or you can just keep prying with a flat head.
*** if you decide to unscrew the handle from the rod, get a permanent marker and mark the top on bottom position of the joint on the rod. If this is not properly marked, you won't be able to open the door from the outside because there will either not be enough leverage to lift the joint up to unlock from the outside or it will be too high and will not close properly cause the lock will never engage.
(1992-95 Civics only)</TD></TR></TABLE>
Old Mar 4, 2006 | 09:08 PM
zoolander's Avatar
Default Re: Door Lock Problems.. (INVALID)
my problem is though, the door is closed, and i can't get it unlocked or open. The latch on the mechanism won't move down and i can't get to the side of the door; since it is closed.
Old Mar 4, 2006 | 09:22 PM
INVALID's Avatar
Wasn't aware it wouldn't allow you to open from the inside of the car. There is a rod running parallel to this line _________________ put your hand on it and pull towards the front of the car.
The up and down part you're talking about is for the key, so if the door is still locked pull that rod up.
This is a 1996-00 isn't it?
Old Mar 5, 2006 | 08:22 PM
zoolander's Avatar
Default Re: (INVALID)
sorry for the lack of info..its a 93 CX. its that up and down part that won't go down. it won't let me unlock it from the inside lock or actually trying to push on the mechanism.
M2B4
Feb 3, 2009 10:38 PM
AxisAccord
Aug 1, 2005 05:41 PM
97itr86
Dec 31, 2004 02:06 PM
vet_girl
Sep 5, 2003 11:49 PM
sleepyhamsterlx
Dec 15, 2002 11:33 AM
