wtb obd2a b series vtec dizzy
I have a new OEM ITR distributor subassembly for sale $160 shipped. Your coil,coil cover,ignitor,and rotor will swap over form your 92-95 civic. All you will need is a new cap for a 94-01 GSR.
joe@carchitect.com
Joe
joe@carchitect.com
Joe
You can use any dohc VTEC dizzy and swap the electrical parts w/harness attached from their stock dizzy into the B-series housing. It's not hard and works good. You will need the shaft/gear stuff from the B-series but all the little black boxes can transfer over. I put my OBD2 D-series guts into an OBD1 LS dizzy, it's working great. Just so you know you have options if you can't find the exact dizzy you want. Also there's really no difference between OBD2 a/b...
Or if you want I have some OBD1 dizzy connectors on a spare parts harness you can have alot cheaper than a complete distributor...Just modify the OBD2 harness if you already have an OBD1 dizzy. Wires are the same it's just the 2 plugs instead of one...
idk if you would be interested, but i have a Obd2 Ls dizzy w/ leg chopped off....fits and works perfectly fine on dohc vtec engine. $70 shipped. If interested just let me know.
