vacume vacume vacume
Ok so i installed my zc head on my block. It has 272 cams in it with dual valve springs, titanium retainers, and ss valves. The problem is i have no vacume to keep it running the cams dont produce vacume till like 1500-2000. Is there any way to get vacume. Nothing will run with out vacume as you know. So im dumping fuel in and fouling out my plugs. Any thoughts? And can i run stock cams with dual valve springs?
I have the same problem you do! Its possible to get a vacume boost pump or just raise the idle to 900-1200! If you do raise the idle watch the cold weather starts. It could cause your crank and rod bearings to fail over time! I recommend the boost pump!
an2ny888
Jun 6, 2006 09:15 AM
