93 Civic Lights out question.
I have a quick question this is for a 93 Civic Coupe. Earlier this week my tail lights have not been turning on. I turn on my side marker those turn on fine and my guage cluster lights up but now that i turn on the normal low beam lights the guauge lights go out and side markers what is wrose it also turns of my rear tailights so at night no one can see me from the rear until I hit the brakes. Any one have Ideas? I check the fuses it seems to be fine I took out the guauge cluster just to make sure everything was plugged in correctly. help please.
God bless.
God bless.
hey man i had the same problem, i thought my head light was out but it was just the fuse. i would go back and check your fuses, and also try to check the wiriing, something could have knocked a wire loose. good luck.peace
-PinoyCivic
-PinoyCivic
Bump
Check all of your fuses...Not just the ones that you think it could be. you might be suprised...I don't think there's any fuses for the lights under the hood, can't remember off the top of my head, but you might want to check there too. If it comes back that ALL of your fuses are good then it would be in your wiring. I wouldn't really pull your cluster and check behind there ( unless you molested some of the wires back there ) start at your lights that your having problems with and follow them to see if theres any cuts in them anywhere...the only other thing that i could think to check would be the bulbs themelsves... good luck.
alfaaay
Nov 10, 2009 05:30 PM
jobe_149
Feb 11, 2005 08:31 PM
