ls rods and crank in a gsr block
Old Mar 3, 2006 | 02:37 PM
egturbolsvtec's Avatar
Default ls rods and crank in a gsr block
I have a ls crank, rods, and ctr pistons. can I put them in a gsr block?
Old Mar 3, 2006 | 02:44 PM
veilsides2000's Avatar
Default Re: ls rods and crank in a gsr block (amb16teg)
i dont see a reason as to why not lol. Yeah you can i'm pretty sure.
Old Mar 3, 2006 | 02:46 PM
Thanks now all I need is a gsr block!
Old Mar 3, 2006 | 05:15 PM
TypRice's Avatar
useable!
Old Mar 3, 2006 | 05:32 PM
da6jdmteg's Avatar
Default Re: (TypRice)
i was going to do that. i was told it wouldnt work out. something aobut the gsr block measurments. is different than the ls. but i could have been told wrong. if it does workout i be mad *** hell.
Old Mar 3, 2006 | 05:48 PM
wingswestrex's Avatar
Default Re: (da6jdmteg)
my buddy did it in his gsr block, when he built his poorman's type r. have the tq of an ls in a gsr block, took the ls crank and rods mated to itr pistons, it works really well
Old Mar 3, 2006 | 07:57 PM
ricebucket's Avatar
Default Re: (wingswestrex)
I've heard that the GSR block has to be "notched" out in order for the LS crank and rods to clear. At least that's what a shop told me when I wanted to do this.
Old Mar 4, 2006 | 03:30 PM
superls92's Avatar
Default Re: (ricebucket)
I've heard that you are supposed to plug up the oil squirters because the crank will hit them, but other then that it can be done most people go with forged internals though.
Old Mar 4, 2006 | 03:48 PM
dohcMONSTER's Avatar
Default Re: (superls92)
the LS crank counterweights hit the oil squirters in the GSR block
Old Mar 4, 2006 | 05:36 PM
Diego Dangers.'s Avatar
any input on why it would be done? wouldnt it be the same displacement? maybe tad longer?
they're both 81mm bore? whats the stroke difference? I'm guessing just rods are the difference?
Old Mar 5, 2006 | 04:17 PM
superls92's Avatar
Default Re: (Diego Dangers.)
Longer stroke for more torque It'll have a little more displacement. basically for some one who wants to have a ls-vtec without having to do a bunch of machine work. golden eagle sells the oil squirter plugs for like 12 bucks. If you want to run stock internals it would be better to run it with vtec pistons because they have deeper valve reliefs, it's a must if you are going to run aftermarket cams.
Old Mar 5, 2006 | 05:20 PM
LS= 89 stroke
GSR=87.2 (i believe...)
either way its a very minimal difference
Old Mar 5, 2006 | 06:54 PM
jdm'dc2sc61's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amb16teg &raquo;</TD></TR><TR><TD CLASS="quote">I have a ls crank, rods, and ctr pistons. can I put them in a gsr block?</TD></TR></TABLE>
it can be done. i did this with my block, all you gotta do is plug up the oil squirters. like someone said earlier, golden eagle sells them for cheap. its the same as an lsvtec (correct me if i'm wrong).
Old Mar 6, 2006 | 03:30 PM
Shaun's Avatar
yup
Old Mar 6, 2006 | 06:14 PM
Thanks for the info guys
patrick4588
Oct 18, 2007 12:33 PM
electric_rex
Dec 5, 2004 02:57 PM
sean
Jan 14, 2004 08:58 AM
