click/clunk coming from tranny when depressing clutch pedal
Old Mar 3, 2006 | 12:57 PM
kevpotts's Avatar
Default click/clunk coming from tranny when depressing clutch pedal
ok when im depressing the clutch pedal, there is a click. pretty loud, and i can sorta feel it in my foot. i had a friend press/depress the clutch while i listened around the clutch m/c and it turns out its coming from the tranny. any one have any idea what it could be? new clutch time? is it something worse? any help is appreciated
Old Mar 3, 2006 | 01:53 PM
Stranger Lupescu's Avatar
I believe we might have the same problem, but I'm not completely sure. Mine sounds just like what you explained, but it cant need a new clutch, cause I just replaced mine. Sorry, cant help but eliminate that.
Old Mar 3, 2006 | 04:07 PM
kevpotts's Avatar
Default Re: (Stranger Lupescu)
ive heard someone say it could be the throw out bearing? i dont know enough about trannys to even begin to diagnose this problem my self. bump for some more help
Old Mar 3, 2006 | 05:58 PM
da6jdmteg's Avatar
Default Re: (kevpotts)
could be throw out bearing. could be worn or fractured pressure plate. if not clutch disc its self
Old Mar 3, 2006 | 06:23 PM
Sturat77's Avatar
Default Re: click/clunk coming from tranny when depressing clutch pedal (kevpotts)
Possible clutch disc, the springs on the disc sometimes get loose and cause strange binding and noise issues between the disc and pressure plate. As they progress, the springs can fall between the pressure plate and disc and cause problems with how it operates (ie. it doesnt operate!). Usually starts as an intermitant problem and gets worse.
'95hatchCivic
Apr 27, 2009 10:20 AM
BoOsTiN Dc2
Jun 16, 2006 05:45 AM
Revi
Jan 11, 2005 05:36 PM
sabertooth
Feb 6, 2004 06:23 AM
greensleeper
Jul 31, 2002 02:33 PM
