Fuel Injection Water Temp Sensor
Old Mar 30, 2002 | 10:08 AM
Import RP's Avatar
Default Fuel Injection Water Temp Sensor
Ok, I was told this might be the problem with the idel on my car. here is a thread explaining what the problem is: https://honda-tech.com/zerothread?id=148423 I talked to my mechanic and he told me to get a new Fuel Injection Water Temp Sensor . I was just wondering if anyone could tell me where it is or how to install it once I get it....thanks!
Old Mar 31, 2002 | 07:23 AM
G's Avatar
G
Default Re: Fuel Injection Water Temp Sensor (Pyrochaos38)
Do the idle screw set procedure before anything. Assuming your TB is clean, the idle screw may need adjusting. The coolant temp sensor is on the head, you can remove it and clean it then put it back. Check your idle set-screw first, clean the TB and set it to idle without the IAC valve. If you don't know the procedure, ask me.....
Better yet, read this:
https://honda-tech.com/zerothread?id=152946
[Modified by G, 8:25 AM 3/31/2002]
Old Mar 31, 2002 | 09:34 AM
Mikey3000's Avatar
i believe the water temp sensor is on the left side of the head (looking at motor from front of car) and it looks like a pin screwed into the head.
Edit: ^^^^^^^^^^^ that's the water temp SENDER. the water temp SENSOR is screwed into the thermostat housing with a 2 plug connector on it.
[Modified by Boss Hogg, 2:57 PM 4/1/2002]
dc4b20
Nov 21, 2012 05:58 AM
SurferDude905
Jun 6, 2009 07:01 PM
quizbo99
May 22, 2008 04:55 PM
OrangeBoost
May 25, 2006 02:46 PM
migs
May 4, 2005 04:35 PM
