Tire Pressure Monitoring Systems from SafeDrives.com and The Tire Rack
Tire Pressure Monitoring Systems from The Tire Rack.
We at Safe Drives LLC are here to bring you and your family great auto safety products and great auto safety information. We are specialists in the field of auto safety products like the one in this ad.
http://www.dpbolvw.net/click-1881633-10410329
The optional display.
We make almost nothing on these items but we think that it is a great product that all of us should have.
They Start at just $229, get yours today!
Details:
Monitoring their car's tire pressures has allowed the world's top race teams to achieve peak performance and analyze potential tire problems before low air pressure could cause an accident or strand their driver by the side of the track. Their tire pressure monitoring system provides the early warning that allows them to correct simple problems before they become catastrophes.
Today you can have that same type of information in your vehicle with the 2nd Generation SmarTire Tire Pressure Monitoring System from The Tire Rack. While it continues to serve as an early warning device that continually checks tire pressure while the vehicle is being driven, the 2nd Generation System is even more adaptable than the original system to better meet the needs of more vehicles. Optional displays and adapters (see list above right) available to finetune the installation for your vehicle. SmarTire Pressure Monitoring Systems alert drivers to small air pressure leaks, before they can become big problems.
So whether you drive around town, on the highway, or at the track, the 2nd Generation SmarTire System can be at your fingertips to warn you of air pressure loss. Additionally, by keeping tires inflated properly, you can maximize performance, fuel economy and tire life all at the same time. And this system can even help protect low profile tires mounted on large diameter wheels by identifying a drop in air pressure long before it becomes visually apparent.
The wireless tire air pressure sensors/transmitters weigh less than 1.5 oz. and are accurate to ±1.5 psi. Straps that accommodate 13” to 20” diameter wheels are used to securely band a sensor to each wheel before the tires are installed. The sensors/transmitters are equipped with motion detectors that turn them off when the vehicle is parked to prolong their lithium batteries' life (estimated at more than 5 years of normal vehicle use).
The system's receiver/display unit is placed within reach and sight of the driver. Within the first minute of driving, the system's sensors will broadcast a signal to the in-car receiver to confirm they are operating correctly. The receiver/display features a 12-volt power cord that can be plugged into the cigarette lighter or hardwired directly to a "keyed" power circuit.
The 2nd Generation SmarTire Tire Pressure Monitoring System is backed by a one-year/unlimited mileage manufacturer's warranty.
The Basic Display System is capable of monitoring four tires and provides early warning of tire pressure loss while the vehicle is being driven.
The compact receiver/display mounts easily to the dash, windshield or center console. No programming is required, just plug in the power cord and the receiver is ready to go. The Basic Display System identifies each tire by its color code (a color coded sensor/transmitter is banded to each wheel along with a matching color coded “washer” that is attached to the tire valve).
If a tire’s air pressure drops to 22 psi, an LED on the display will turn red to identify the problem tire. The vehicle can be pulled to a safe location and the tire associated with the color adjacent to the red LED can be inspected. If air pressure continues to drop to 18 psi, the second level warning will activate an audible alarm and the LED will flash red.
Get yours HERE! http://www.dpbolvw.net/click-1881633-10410329
Auto Safety Products,
Auto Safety Information,
http://www.SafeDrives.com
Details:
J28S
May 21, 2002 03:09 PM
